Thread: possible work around for bleeding ABS system?
Results 1 to 6 of 6
  1. #1 possible work around for bleeding ABS system?
    Dec 2013
    Niagara Falls Ontario
    Wondering if anyone knows if there is a way to bleed the air out of an ABS system on a GP 2006 base model with traction control, that doesn't require a scan tool?
  2. #2 Re: possible work around for bleeding ABS system?
    Dirt road, by yourself.
    Stomp on them a few times to try and cycle the ABS pump, don't do any crazy speeds where you'd lose control though.
  3. #3 Re: possible work around for bleeding ABS system?
    Then I'd go around and re-bleed each caliper if needed.
  4. #4 Re: possible work around for bleeding ABS system?
    Dec 2013
    ok i'll try that. do you know of any other techniques i could try if that doesn't work?
  5. #5 Re: possible work around for bleeding ABS system?
    Dec 2013
  6. #6 Re: possible work around for bleeding ABS system?
    Sep 2014
    chicago
    Get some Russell speed bleeders, it takes like 20 sec to bleed each caliper by yourself. These things are golden
  1. Having trouble bleeding the cooling system
    By LHRxXD3adXx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2014, 06:49 PM
  2. Fuel Injection/System Cleaners? Do They Really Work?
    By ThaUnknownOne in forum 5.3L V8 (LS4)
    Last Post: 07-12-2013, 12:16 PM
  3. Bleeding PS system?
    By atomicjoe23 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:42 PM
  4. need help with bleeding coolant system
    By loganrick in forum Engine
    Last Post: 12-26-2011, 01:10 PM
