Thread: Please HELP! $1,400 for rear suspension?!?!!?
Results 1 to 7 of 7
  1. #1 Please HELP! $1,400 for rear suspension?!?!!?
    Apr 2015
    Massachusetts
    Hi my mechanic informed me today that it will cost 1,100 in parts alone for Bilstein springs, shocks and upper mounts. I tried to search online for discounted or compatible ones but there are nothing for 06 GXP's only the non-GXP versions. Are there any places that sell the discounted Bilstein stuff I need? Are there compatible, just as good other brands? If so where can I get them, what model should I look for?
  2. #2 Re: Please HELP! $1,400 for rear suspension?!?!!?
    Feb 2013
    Missouri
    Bilstein doesn't make the springs or the top mounts, just the struts. You can find them on Amazon pretty cheap. You can use your current springs and PROBABLY your current mounts. The rears don't normally get that damaged. let me see if I can find the link for the struts...
    http://www.amazon.com/ACDelco-505-54.../dp/B0016I8JJO
    If the dumbass wanted to charge you $1100 for struts walk away. No RUN away. Do it yourself or take it to someone else.
  3. #3 Re: Please HELP! $1,400 for rear suspension?!?!!?
    Apr 2015
    Massachusetts
    are those just as good as Bilsteins for a 2006 Grand Prix GXP 8 cylinder 18" wheel model?
  4. #4 Re: Please HELP! $1,400 for rear suspension?!?!!?
    Feb 2013
    Missouri
    They are bilsteins.
  5. #5 Re: Please HELP! $1,400 for rear suspension?!?!!?
    Apr 2015
    Massachusetts
    Thanks for the info man I just ordered them! Now I just gotta decide if I should have my mechanic install them or do it at my dad's friends house.
  6. #6 Re: Please HELP! $1,400 for rear suspension?!?!!?
    Feb 2013
    Missouri
    Do em at your dad's house. Rent some spring compressors, take the top mount off, move the boot\bumpstop over to the new strut, move the spring over, put the top mount on the new strut, release the spring compressor, put strut back in.
  7. #7 Re: Please HELP! $1,400 for rear suspension?!?!!?
    Donating Users timboku's Avatar
    Montgomery, IL
    Just outta curiosity what happened to the rear suspension that it failed, usually fronts go out way before rears..I have 120k on my gxp all orginal strutd..it's not new but the suspension still works...I bought new bilsteins and will be lowering it this summer but mine is still fine.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  1. Stiffer rear suspension? 97-03
    By 01Blackgtp in forum Brakes/Suspension/Chassis
    Last Post: 09-15-2014, 10:50 AM
  2. rear suspension????
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-07-2010, 04:29 PM
  3. Rear Suspension Question
    By BigTony08 in forum Brakes/Suspension/Chassis
    Last Post: 04-03-2010, 08:14 PM
  4. rear suspension, 04+
    By sportred04 in forum General Tech Discussion
    Last Post: 03-09-2010, 07:20 PM
  5. Rear suspension help
    By thirdgenfcarnut in forum Brakes/Suspension/Chassis
    Last Post: 08-16-2009, 04:25 PM
