Thread: Breaking endlinks in half violently
Results 1 to 15 of 15
  1. #1 Breaking endlinks in half violently
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I have moog poly endlinks on my doorman front sway bar. They are the black coated ones with white bushings. Extremely firm and feel wonderful. I love them. Only problem is that they tend to snap in half when cornering very aggressively. I have tried overtightening and undertightening them with the same result. The only way I can keep them together is to replace the center bolt with a hardened bolt from the hardware store. Obviously its fairly violent when it happens and the car becomes very loose which can be a tad dangerous while cornering at 70+. Ask me how I know.
    Anyone else have this issue? I just snapped a week old endlink today.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #2 Re: Breaking endlinks in half violently
    Arizona
    Of youre lowered you need to just a bolt and the bushings without the center portion. It helps tremendously. To getthe sway bar level with the lca
  3. #3 Re: Breaking endlinks in half violently
    yeah, your sway bar is preloaded when lowered because of the incorrect length of the end link.
    i have the same issues with my V.
  4. #4 Re: Breaking endlinks in half violently
    Apr 2011
    South Dakota
    Im not lowered though?
    I love Decker<3
  5. #5 Re: Breaking endlinks in half violently
    Feb 2013
    Missouri
    Sorry to thread jack, but would Vogtlands warrant the smaller endlinks? They're not that much lower than stock, that's the only reason I ask.
  6. #6 Re: Breaking endlinks in half violently
    look at your sway bar position. it should be level with no preload on it when the car is sitting on the ground.
  7. #7 Re: Breaking endlinks in half violently
    GT Level Member yzboy85's Avatar
    Dec 2013
    maine
    I had a pair of those same end links snap on me as well. I wasn't lowered and had literally just replaced everything in the front end. I ended up putting the rubber ones that came with my swaybar (gmpp) on instead. I was kind of disappointed that I didn't have poly bushings anymore but so far they've worked fine.
    02 GTP Coupe - Jennifer
    SD headers, SLP Powerflo catback, 3.4, CAI, Shift Kit, GMPP Sway Bars, F-Body Brakes
  8. #8 Re: Breaking endlinks in half violently
    Dec 2008
    Lawndale, CA
    Maybe you will have better luck with the blue one's from Moog.
  9. #9 Re: Breaking endlinks in half violently
    Apr 2011
    South Dakota
    Blue ones are squishy. Then my car converts to oversteer insanity.
    I love Decker<3
  10. #10 Re: Breaking endlinks in half violently
    Arizona
    All you need is grade 8 bolts washers and universal poly end link bbushings. Your problems will be solved
  11. #11 Re: Breaking endlinks in half violently
    Til you do what I did........
    I tore the perch off the control arm.
  12. #12 Re: Breaking endlinks in half violently
    Sep 2014
    Worcester, MA
    Quote Originally Posted by Frosty View Post
    Do you have new springs? Or still the factory ones which are probably worn out so your car sits lower?
  13. #13 Re: Breaking endlinks in half violently
    The bar is basically always preloaded unless you use one adjustable link which is adjusted when the car is in "racetrim" with a ballast for the driver, and the average amount of fuel you typically have.
    Even then, it'll be at zero preload for that one specific condition. Have more people, preload changes.
    The bar being parallel to the ground is for correcting the angle at which the bar acts on the lower control arm. The closer to 90*, the higher the mechanical advantage, making the bar more effective.
    Some instruction on the procedure: http://www.powergridinc.com/pdf/Powe...structions.pdf
    If the OP is breaking bolts, perhaps the grade 5 bolts they likely come with aren't up to the job. Consider grade 8. Another consideration would be using more spring rate instead of relying just on the sway bar.
    Seems someone has already purchased Powergrid links for an 04-08 Grand Prix: http://www.powergridinc.com/swaybar_...r-Pontia-56952
  14. #14 Re: Breaking endlinks in half violently
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So these white bushings are harder than the blue? I didn't realize there were different stiffnesses of the poly bushings for the endlinks.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  15. #15 Re: Breaking endlinks in half violently
    Arizona
    Why not just use the red at autozone
  1. Breaking into my own car
    By 87IROCZOWNER69 in forum General Grand Prix Discussion
    Last Post: 01-03-2014, 06:53 PM
  2. breaking bad
    By z3r0 in forum The Rant Forum
    Last Post: 11-12-2011, 02:46 PM
