Thread: Impala Brakes is it true
Results 1 to 16 of 16
  1. #1 Impala Brakes is it true
    Feb 2010
    TN
    Ok I know about f-body swaps but someone told me impalas have a dual piston front brake and if I get it with the bracket and a set of rotors they are a direct swap.. Antone know if this is true, and what years and models are swappable, also does anyone know if a 2001 chevy venture van and a 1997 grand prix use the same brake set up so if it does I can use this on that as well?
    Thanks everyone
  2. #2 Re: Impala Brakes is it true
    Donating Users timboku's Avatar
    Montgomery, IL
    Its true. I think its like a 06 up that has the dual calipers. Cant really remember. And yes, they will bolt onto the mini van as it uses the same spindle. However you need to make sure the tires on the minivan will clear the bigger brakes if you go that route. Not sure what size are on the mini van.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #3 Re: Impala Brakes is it true
    Feb 2010
    TN
    p215 15's
  4. #4 Re: Impala Brakes is it true
    15's are too small.
  5. #5 Re: Impala Brakes is it true
    Montgomery, IL
    15s will not work..16s barley clear
  6. #6 Re: Impala Brakes is it true
    Feb 2010
    TN
    Ok I was going to put the Pontiac Rims on it it sooner or later so, sooner it is. and how sure are we its 2006 and up for calipers
  7. #7 Re: Impala Brakes is it true
    Montgomery, IL
    99% sure its 06+ montes/impalas
  8. #8 Re: Impala Brakes is it true
    St. Louis
    It's 06+. I have them on my 00 GPGT right now with stock 16" wheels. You may have to bend the bracket that holds the brake line to the frame to be sure the hose didn't get in a bind when turning lock to lock. I did on my GP. They are dual piston and steel, unlike the F-bodies which are aluminum. All the bolts/hardware from the Imp bolted right on without any adapters. I have a post somewhere on here that shows how they fit and what I did. A quick search should turn up more info as well.
  9. #9 Re: Impala Brakes is it true
    Pennsylvania, USA
    Don't forget the banjo bolt if I the calipers don't come with one. You can buy a bit of extra brake line and make a short section that turns 180 degrees at the bracket to give your brake line some extra room.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  10. #10 Re: Impala Brakes is it true
    Feb 2010
    TN
    New question will 1998 Firebird rotors fit with the impala calipers and brackets on that 2001 Venture?
  11. #11 Re: Impala Brakes is it true
    Feb 2013
    Missouri
    No, they are too thick. After getting them turned a few times you might be able to get them to fit, but you would have to trim hardware on the brackets too.
  12. #12 Re: Impala Brakes is it true
    Feb 2010
    TN
    Thanks
  13. #13 Re: Impala Brakes is it true
    Quote Originally Posted by Logan541 View Post
    just use the rotors for the calipers you choose to use. those are the rules pretty much.
  14. #14 Re: Impala Brakes is it true
    Feb 2013
    Missouri
    From what I've read, the 00-05 Impala (single piston 12 inch brake upgrade) and the F-Body rotors are the same, but the 06+ Impala rotors are different.
  15. #15 Re: Impala Brakes is it true
    iirc they are all a bit different, big bad brake thread had it all laid out.
    to be safe, just use what your supposed to use with each caliper.
  16. #16 Re: Impala Brakes is it true
    Feb 2013
    Missouri
    ^^I agree, but when wandering junkyards, it's nice to know what you can use from one vehicle to another. Oreilly's lists the same part number for a front rotor on a 2003 Impala and 2000 Camaro. 56641RGS, that said, they might be slightly different, but apparently they are interchangeable.
  1. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  2. 06+ Impala front brakes in and done!
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 09-06-2013, 09:27 AM
  3. Impala SS brakes
    By Eric Whitter in forum Brakes/Suspension/Chassis
    Last Post: 03-26-2013, 08:09 AM
  4. 06+ impala front brakes
    By usetaboost in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2013, 08:42 PM
