Thread: Impala SS brakes
Results 1 to 4 of 4
  1. #1 Impala SS brakes
    House springs missouri
    I have a friend that upgrade brakes on his 2004 Impala SS and he bought 2 pairs of rotors and I was wanting to know if I could upgrade the rotors on my 98 GTP to those
  2. #2 Re: Impala SS brakes
    Dec 2010
    DMV
    You need bigger caliper brackets to accommodate bigger rotors.
  3. #3 Re: Impala SS brakes
    you need the caliper, caliper brackets, and the rotor.
    or upgrade to f body brakes up front, same parts list. either one works well.
    lots of threads here covering both swaps.
  4. #4 Re: Impala SS brakes
    Banned
    Jan 2013
    maryland
    This
    And more of This.
    When i did my setup i grabbed R1 drilled rotors for the 2006 impala went to the junkyard and grabbed the calipers and brackets (make sure the caliper bolts arent stripped i made that mistake) oh and you should probably upgrade your brake lines to SS lines as well my 2cents
    Sent from my SGH-T989 using Tapatalk 2
  1. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  2. 06+ impala front brakes
    By usetaboost in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2013, 08:42 PM
  3. Brakes squealing even after foot is off brakes
    By GTLGDP in forum General Tech Discussion
    Last Post: 06-26-2012, 09:16 PM
