Thread: building struts need help
Results 1 to 20 of 27
  1. #1 building struts need help
    GT Level Member m17davis's Avatar
    Orland Park, IL
    I'm going to be buying kyb agx struts all around. My main question is where to buy everything from. Also what do i need. For the struts I will be ordering them from parts geek. For lowering springs what should I do? Mounting kits and boots and stuff? Never built a strut if you couldn't tell. Lol
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: building struts need help
    Monroe strut mounts.. SSC springs.. Reuse everything else from the factory strut.
    04 Comp G.
  3. #3 Re: building struts need help
    Orland Park, IL
    Matic plus or oespectrum
  4. #4 Re: building struts need help
    Dec 2008
    Lawndale, CA
    This. If you want to just lower it a little then vogtland springs. I would replace the endlinks as well with Moog's while you are working on the struts.
  5. #5 Re: building struts need help
    I would also take the opportunity to change out the CA while your there depending on the condition/mileage of your current ones.
    04 Comp G.
  6. #6 Re: building struts need help
    Orland Park, IL
    I'm confused. Are you saying to reuse the stock strut?
  7. #7 Re: building struts need help
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by m17davis View Post
    He means the boot and the foam isolator things from the old strut I think..no.need to buy new ones of those.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  8. #8 Re: building struts need help
    Orland Park, IL
    Gotcha. Thanks. Is it overkill to get agx?
  9. #9 Re: building struts need help
    Ehh debatable.. Some guys will say the excels are just as good and last longer then then agx.. Others will argue against that. Personally I'll give the $200-250 excels a shot first and use what you would of spent on swapping out the front sway for a Dorman and some new control arms.
    04 Comp G.
  10. #10 Re: building struts need help
    Dec 2008
    Lawndale, CA
    You also have this option.
    http://www.grandprixforums.net/threa...-with-KYB-tech
    My brother ran these for awhile on his 03 with vogtlands. I posted a review towards the end. He now has AGX's. The AGX's ride a little better.
  11. #11 Re: building struts need help
    Orland Park, IL
    Sweet. Thanks. If I'm buying agx struts, you said to buy Monroe strut mounts? So I would be buying 4 mounting kits from parts geek?
  12. #12 Re: building struts need help
    Yup or just grab them from advance order online use coupon code and pick up in store
    04 Comp G.
  13. #13 Re: building struts need help
    Orland Park, IL
    Then. The grand total with agx, ssc, mount kits, shorter dog bones, engine and tyranny spacers. 840. Sound about right for about 2 inches? Lol
  14. #14 Re: building struts need help
    I'd go coilovers but that's just my opinion lmao
    04 Comp G.
  15. #15 Re: building struts need help
    Orland Park, IL
    No way. I can't pay $1460 for coilovers. I would love to have them but thats out of my budget. If there was a cheap way to make them myself I would.
  16. #16 Re: building struts need help
    Nov 2012
    Madison
    Why shorter dogbones?
  17. #17 Re: building struts need help
    There is a cheap way.. Plenty of info on this site on how to make em... Gotta do your homework and search! And **** shorter dogbones.. Do it the better way and get Vinnie spacers instead.
    04 Comp G.
  18. #18 Re: building struts need help
    Enfield, CT
    well where can the Vinnie spacers be found? lol
  19. #19 building struts need help
    Uh noobs contact him. And before someone says ahh I'll just get them from ZZP well ZZPs sucks and aren't the correct size. Plus support the little man.
    http://www.grandprixforums.net/threa...ration-Spacers
    04 Comp G.
  20. #20 Re: building struts need help
    Enfield, CT
    uhh IK to contact him nor am I looking for a set. Just wanted to be an asshole lol
  1. Building a new RIG
    By Alix0r in forum Off Topic Discussion
    Last Post: 01-23-2014, 03:06 PM
  2. Building my bro a PC.
    By Odi in forum Off Topic Discussion
    Last Post: 01-07-2012, 04:41 AM
  3. Building a Sleeper
    By gtp20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2011, 01:04 PM
  4. Building a S/C 5spd..
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-16-2010, 12:29 PM
  5. Help with building a sub box
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-27-2010, 11:35 AM
