Thread: Thumping and Pulling
Results 1 to 6 of 6
  1. #1 Thumping and Pulling
    Apr 2011
    Ohio
    Hi everyone. I am having an issue with a thumping noise and vibration coming from what I believe to be the front passenger side wheel. The vibration can be felt from about 35 mph+ and is worst at about 75 mph (which is annoying because I have a highway commute). I can hear the "thumping" sound coming from the front end and can feel it pretty violently through the steering wheel. I checked my tire--it's not cupped at all. Additionally, I had both front wheel bearings replaced about 4 months ago, so I doubt it's that. The car also, left to its own devices, pulls slightly to the left. It's not bad, but when I have to adjust the steering accordingly (i.e. countersteer about 5 degrees to the right) the vibration gets worse. Any suggestions?
  2. #2 Re: Thumping and Pulling
    Kinda sounds like a seperated tire to me.
    But I'd have to see it in person to really know what it is.
  3. #3 Re: Thumping and Pulling
    Apr 2011
    Ohio
    Is there a way I could diagnose a separated tire? Other than just getting them rotated and seeing if the sound moves?
  4. #4 Re: Thumping and Pulling
    Enfield, CT
    I would double check the hubs even tho they are new because they may be defective and like FFDP said maybe it's a belt shift/separation. This is one of those things that require physical inspection. You could try to post some pics and maybe we can see something.
    Start small and rotate the tires
  5. #5 Re: Thumping and Pulling
    St. Louis
    Sounds like a hub to me. My drivers side was doing this and when I went to change it, it came out in 2 peices.
  6. #6 Re: Thumping and Pulling
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    Tie rod joint
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SKĀ® 4T65E Transmission Shift Kit, 180* Thermostat
  1. Popping and Thumping noise.
    By Brammer in forum General Tech Discussion
    Last Post: 10-21-2013, 07:09 PM
  2. Thumping noise.. wheel dependent.. what is it?
    By NaturallySmashed in forum Brakes/Suspension/Chassis
    Last Post: 07-03-2013, 01:15 PM
  3. Thumping noise when braking
    By 400exHauler in forum General Tech Discussion
    Last Post: 10-11-2010, 12:46 AM
  4. Parking Brake Thumping/Stuck On?
    By LuckyBambu in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2010, 09:51 AM
  5. Light Thumping sound under car :S
    By 9ordohz in forum General Tech Discussion
    Last Post: 02-18-2010, 12:47 PM
