Ok gp family, for a cost of 21.99 per arm and a couple of bushings you can have trail8ng arms that surpass any upgrades currently available. If you have a tractor supply or cal ranch store near ypu then these are readuly available. All others must order them.
Parts list of what youll need
2x toplink cat 1 part number 0267759.
The bushings will have to reduce from the 3/4 in bolt hole. So for the rear bolt i used 3/4 to 5/8 bushing (also found next to the links) part # 0269002 x2
The front bolt for the actual bracket, i chose to make accept a 1/2 bolt which required a very slight reaming of the bracket. Its on you how far you want to offsett left or right to cleqr your tires. Im on 245s in the rear 7"rim standard gxp rim.
Bushing will need to be from 3/4 od to 1/2.
Other things i should lve bought at the time were nuts for both rod ends to keep them locked.
Anyway this is how itll came together.
