Thread: springs and swaybar
Results 1 to 7 of 7
  1. #1 springs and swaybar
    Nov 2014
    winston salem,nc
    okay guy got a 98 gp se, working on a budget, what springs would you all suggest? the car is my dd, im looking at zzp (i know to get the anti pogo washers, shorther wishbones etc) and gmpp sway bars, would this be a good set up? and im looking at kyb adjustable shocks but is the a cheaper option? or what set up should i get? also i note my 3 month old daughter will be rideing in it so dont want to feel like im on heated/cut springs lol been there and done that with a 240sx and hit the roof more times then i could count
  2. #2 Re: springs and swaybar
    Nov 2014
    winston salem,nc
    *guys i ment
  3. #3 Re: springs and swaybar
    Feb 2013
    37.295091, -121.930053
    you do know you can go back in and edit your posts
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: springs and swaybar
    Nov 2014
    winston salem,nc
    yeah but for some reason my computer will not let me hit the save button lol
  5. #5 Re: springs and swaybar
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    The KYB Gr2 are a cheaper optiom many use for struts
    As for front sway bars get a dorman one, its cheaper and better than the gmpp bar.
    Springs depends on how low you want to go we should have a sticky that shows cars with different spring setups, and i would use mount spacers over shorter dogbones.
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: springs and swaybar
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    Look at this thread, http://www.grandprixforums.net/threa...k-in-here!!,it shows different brands of springs on cars. Like Russ said there are the Gr2's and they work great for me with B&G's. They are a little rougher than OE springs but not back breaking and give a great stance. Also do not get the shorter dog bones get the mount spacers, work much better for correcting the axle geometry.
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  7. #7 Re: springs and swaybar
    I've had the GR2's on Vogtlands for 90K and they are still fantastic. Meanwhile friends with AGX's seem to have failures. And there is a thread here where someone called KYB and their tech said the gr2 was better suited to lowering. I believe it has more travel available.
    For anti pogo's.. take an 18mm socket and breaker bar to a JY. Get rear subframe washers from a W body, that's the same thing ZZP is going to sell you. Bet the JY is better for your budget.
  1. Swaybar Sizes
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2024, 05:51 AM
  2. 04 gtp swaybar?
    By Akuch26 in forum Brakes/Suspension/Chassis
    Last Post: 08-27-2014, 05:13 AM
  3. 04 gtp swaybar?
    By Akuch26 in forum 04+ Specifics
    Last Post: 08-23-2014, 12:20 AM
  4. swaybar install
    By GTP GTP GTP in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2012, 05:34 PM
  5. Swaybar Brackets...
    Last Post: 11-13-2009, 01:07 PM
