Thread: Could this cause my "thunk"?
Results 1 to 11 of 11
  1. #1 Could this cause my "thunk"?
    Mar 2014
    Tucson
    Here's the details:
    2000 GTP Sedan. 153K miles.
    New sway bar end links, outer tie rods, and right hub bearing.
    I am hearing a noise that is something between a click and a thunk coming from the right front. It is most pronounced when going from drive to reverse with the wheel all the way to the left. However, it can also be heard with the wheels straight or to the right and going from reverse to drive, just not as loud.
    Hoping you guys can help me diagnose so I don't just throw random parts at it. Just what's needed as it's needed.
    Could this be my culprit?
  2. #2 Re: Could this cause my "thunk"?
    you lca's are shot, get new ones.
  3. #3 Re: Could this cause my "thunk"?
    Mar 2014
    Tucson
    Cool. Well, not cool, but now I know at least. From what I've read, most people say to replace the entire arm and I'm okay with that. Are stock Dorman's the best or is there a stock(ish) upgrade? Think I remember reading something about fleet vehicle arms. Like the Impala taxis or cop cars. Would those be a better, or even feasible option? Not looking for a track car, but the roads here in Tucson super SUCK!
    I'm also cool with replacing just the bushings. Time and labor aren't an issue. Money is. Is it worth the savings to do that?
  4. #4 Re: Could this cause my "thunk"?
    after part by part replacing bad front end parts, it was the lca's that stopped the clunking i had.
    i used dorman's they were like 40 a side. moog makes one with a grease able ball joint. its a few bucks more.
    check rockauto and partsgeek. or amazon, buying them local is just crazy. they want like 70 a side.
  5. #5 Re: Could this cause my "thunk"?
    Mar 2014
    Tucson
    Okay, I found the post about the fleet vehicle arms:
    Quote Originally Posted by HighOctaneRacing View Post
    Here's the impala police package part numbers for dorman LCAs
    Left 521029
    Right 521030
    They will fit and look exactly the same as OE ones but have a stronger ball joint and stiffer bushings
    Has anyone used these? Can someone confirm they will work on a 2000 GTP?
  6. #6 Re: Could this cause my "thunk"?
    google the part #'s.....why you need your hand held? lol
    this is the left side http://www.amazon.com/Dorman-521-029.../dp/B004AINV3G
    you can get the right one on your own. keep searching around on line, see if you can find a better price. these be pricey.
  7. #7 Re: Could this cause my "thunk"?
    Mar 2014
    Tucson
    No hand holding needed. Got both part numbers. Found best price. Ready to click purchase....
    Visually, they look similar. Just hoping someone would say "Yup, I installed them, They fit." Because it's not a direct replacement, none of the usual "will it fit" guides approve.
    Just looking for some community feedback is all.
  8. #8 Re: Could this cause my "thunk"?
    Mar 2014
    Tucson
    I think I'm going to give them a shot. Worse case scenario, I'm out the money to ship them back.
    http://www.amazon.com/dp/B004AINV3G/...I2QXG7FZ3UMPI9
    http://www.amazon.com/dp/B004AINV40/...I2BIYWF789GTWN
    They're only $10 more per arm than the standard Dorman replacements.
  9. #9 Re: Could this cause my "thunk"?
    those are good for a impala, so they should fit fine. i searched for a 2000.
  10. #10 Re: Could this cause my "thunk"?
    Mar 2014
    Tucson
    Cool. I didn't know if the Impala and GP front suspensions were the same. I suppose it makes sense. Aren't the cradles similar/interchangeable? (Asking just for the sake of knowing)
  11. #11 Re: Could this cause my "thunk"?
    yup. people take the suspension parts off the cop impalas all the time. rear bars all work too. its all the HD parts. what you ordered should be the same.
  1. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  4. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  5. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
