I'm going to post this in the hopes that perhaps somone has either seen this, or has a solid idea of where the problem may lie:
Car: 2001 GTP. Front end: recent timken Whl.Brngs, Fbody discs, C6 calipers-Not hanging, braided hoses, No worn Susp. parts from the inner tie rods out. This setup has about 5K miles on it, the car has 111Kmiles. Problem, ~1oo miles ago it began.
Problem Circumstance: The Steering behave normally at all times EXCEPT> When making a hard, tight (typically a street corner) Right hand turn Only, After a Moderately Hard to Hard Break application. This is the ONLY time the problem occurs.
Problem:Under the above situation, there is a loss of power assist (Not Magnasteer BTW), which returns as soon as the turn is complete. There is no detectable brake pull, rotor and caliper Temp checks show consistent temps side to side all the way up to 600F+ on eash rotor.
Checks performed: No leaks, PS pump full, Modis scan reveals no abs codes. Driving in a large parking lot and replicating the behavior shows that if a hard right is performed Without First Braking, there is No loss of power assist, also there appears to be no loss of power when the car is placed in neutral and similar manuevers are performed. A medium speed "Cone Style" slalom also reveals no loss pwr assist.
Thoughts: Perhaps the pump is a bit weak, perhaps the fluid is shot and a change would help, perhaps the rack may have failed in such a way that this is in fact the Power section of the rack. Perhaps a Shot of lucas Power Steering Fix in a bottle would "fix" it(Gulp!)...And I've got a 99 gtp with 133K miles that works fine-and a 97 gt with 260Kmiles that works as well.
So where to start? Changing the rack is the biggest PIA, the pump is less work, Fix in a bottle is the least. But since this ONLY occurs immediately after, Or During heavy Brake Application, How is it that the Brake system can be ruled out? If the deceleration G's were to blame, the problem should occur on left hand turns as well, which would make me think that the binders are involved--like one side is hanging...But brake temps don't bear this out concluively, even after 10-15 minutes of parking lot punishment. Also there are no wierd noises from the pump or rack that I can hear while driving and the behavior is no different with the ABS/TC turned off.
I think I've covered about everything, but if anyone has ideas on further testing, or has experienced anything like this, I'd Really Love to hear From You! Thanks in Advance, Mike
PS, the 99 and 97 are--as of today, complete, and are designated parts cars, so I can swap watever I need-provided it fits, and I really should list them in the F/S section for anyone that nees cheap or free parts. I'll try to do that soon.
