Thread: Power steering hum?
Results 1 to 8 of 8
  1. #1 Power steering hum?
    Feb 2013
    Minnesota
    My 01 Grand Prix Has a humming noise in te front end when I make a sharp turn. It almost sounds like a dry pump pumping. There is power steering fluid in it, but I think the pump is going out. I can feel the vibration in the steering wheel. Also once on a great while when I'm braking and the noise comes in with my steering wheel turned my antilocks kick in. Any ideas?
  2. #2 Re: Power steering hum?
    Feb 2013
    Minnesota
    I Actually haven't checked the power steering fluid. But I'm assuming there's fluid in it if it turns easy
  3. #3 Re: Power steering hum?
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    Low fluid / air in the lines.
    I just (Last night) replaced the pump, rack and return line after the leaking return line emptied my system 200 miles from home. Not exactly what I wanted to do with that $500.00, wish I caught the leak sooner.
    Check / Re-Fill your fluid, and find out where it's leaking at!
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  4. #4 Re: Power steering hum?
    Feb 2013
    Minnesota
    How do you even check the fluid. I can't seem to find the reservoir
  5. #5 Re: Power steering hum?
    Oct 2012
    Pinckney, MI
    It's behind the alternator, under the heater core hoses.
    -Rob
  6. #6 Re: Power steering hum?
    Feb 2013
    Minnesota
    Do I need to remove the alternator or coolant Reservoir to get at it?
  7. #7 Re: Power steering hum?
    Oct 2012
    Pinckney, MI
    Nope, just squeeze your hand in between the two coolant hoses and it's right there.
    -Rob
  8. #8 Re: Power steering hum?
    Feb 2013
    Minnesota
    Alright man thanks! I'll post what I find in a bit
  1. Power Steering
    By RustyHO in forum General Tech Discussion
    Last Post: 04-01-2013, 05:55 PM
  2. power steering help
    By redefine91 in forum Brakes/Suspension/Chassis
    Last Post: 12-22-2011, 03:15 PM
  3. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  4. Power steering?
    By apierce1289 in forum General Tech Discussion
    Last Post: 03-11-2011, 04:27 PM
  5. Power steering box
    By j3knoll in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2011, 08:44 PM
