Thread: Anyone running the Dorman rear stabilizer bar 927-110?
Results 1 to 5 of 5
  1. #1 Anyone running the Dorman rear stabilizer bar 927-110?
    SE Level Member chrisdaboss's Avatar
    May 2013
    Houston
    I want to know if you all used the bushings it came with or bought some other ones like the Moogs. Also, did the Dorman one provide a noticeable difference, I know the front sway bar will but just curious on other people's thoughts. I got it for a good price I guess, idk if it was a waste of money "upgrading" the rear bar. Is the rear dorman one an upgrade? I was going through the sticky but searching on this forum... yeah I'm not going that route. thanks
    This is where I'd put my mods, if I had any.
  2. #2 Re: Anyone running the Dorman rear stabilizer bar 927-110?
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Go with poly bushings and some new endlinks for sure. And the bar is definitely an upgrade over stock and you'll notice a difference.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  3. #3 Re: Anyone running the Dorman rear stabilizer bar 927-110?
    May 2013
    Houston
  4. #4 Re: Anyone running the Dorman rear stabilizer bar 927-110?
    Buffalo, NY
    Ya those are the ones
  5. #5 Re: Anyone running the Dorman rear stabilizer bar 927-110?
    May 2013
    Houston
    Kewl
  1. Running front o2 in place of rear o2
    By dsmuts in forum General Grand Prix Discussion
    Last Post: 04-17-2014, 12:06 AM
  2. Upper bolt on rear stabilizer bar
    By regal180 in forum Brakes/Suspension/Chassis
    Last Post: 02-01-2012, 10:48 PM
  3. Stabilizer bar change??
    By craig1980 in forum General Tech Discussion
    Last Post: 08-15-2011, 10:00 PM
  4. any1 running 255 45 17 on the rear???
    By GTPJOE90 in forum Tires & Wheels
    Last Post: 02-16-2009, 03:13 AM
  5. Lucas Oil Stabilizer
    By millfire517 in forum General Tech Discussion
    Last Post: 02-10-2009, 10:14 PM
