Thread: Alignment after new Struts
Results 1 to 13 of 13
  1. #1 Alignment after new Struts
    Oct 2014
    Minnesota
    I apologize in advance for there probably being another thread like this.
    Probably a stupid question, but I am wondering how soon after replacing my front struts and all new wheel bearings that I should get my car aligned. I just got new tires, so I am a little paranoid. I am planning on doing the repairs at home in the shop on a weekend, but I have a 3 hour drive back to where I am working an internship which is where I would get the alignment done during the week. Is this driving too far with potentially bad alignment?
    I have also read places that it is good to let the new struts settle for a while (about a week) before aligning. Note that when I say strut, I mean the pre assembled ones with new springs and mounting plates with the spring already compressed and installed in the assembly. Thanks for any input.
  2. #2 Re: Alignment after new Struts
    As soon as possible.. You want a alignment right after replacing your struts.. Bearings on the other hand doesn't change the geometry of he suspension so if you did just bearings you don't have to worry bout it.
    04 Comp G.
  3. #3 Re: Alignment after new Struts
    let them settle for a couple of days, then get an alignment. a few days of driving isn't going to destroy a set of tires.
  4. #4 Re: Alignment after new Struts
    Buffalo
    Best investment after buying a car is to get a lifetime alignment from firestone and use a coupon
  5. #5 Re: Alignment after new Struts
    Quote Originally Posted by crazyguy03 View Post
    nah. those guys don't know **** about alignment.
    "within spec" isn't a good alignment. ever.
  6. #6 Re: Alignment after new Struts
    Buffalo
    What would you recommend ? The dealership?
  7. #7 Re: Alignment after new Struts
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    The dealership that did my alignment was full of retards.
    They BARELY put everything in spec and didn't bother too center the wheel. I went to a local Belle Tire and those guys were great.
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: Alignment after new Struts
    an independent shop that has a good alignment machine and that'll let you recommend the settings.
    as well as actually get them all even and as close to 'perfect' as possible. a truly good alignment makes a car awesome to drive.
  9. #9 Re: Alignment after new Struts
    Buffalo
    I hear ya, but for the average person , can't go wrong with lifetime.
    I myself know of a few "bad" locations and don't go back there. The one I like , let's me do what you described. He is a good manager there and helps out.
  10. #10 Re: Alignment after new Struts
    the shop i typically go to for my good alignments lets me stand in the shop while they work.
  11. #11 Re: Alignment after new Struts
    Buffalo
    yep. Me too Usually tells me to come back when it's a bit slow, go over things together etc...
    If anyone is local, it's at Dick and George Urban
  12. #12 Re: Alignment after new Struts
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    I got an alignment about a week after doing struts and control arms and it didn't hurt my new tires at all. I don't do a lot of driving in a week but it's probably somewhere around the 3 hour trip worth that you're doing.
    I've never been there it's a little far but have you ever been to Russo's downtown?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  13. #13 Re: Alignment after new Struts
    Oct 2014
    Minnesota
    Thanks for the input guys.
  1. Alignment
    By kissmyss in forum Tires & Wheels
    Last Post: 06-08-2014, 10:19 PM
  2. How's my alignment look?
    By LS1GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2013, 07:45 PM
  3. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  4. Alignment
    By dsh1106 in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2011, 10:39 AM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
