Thread: Driven for months without power steering.
Results 1 to 20 of 30
  1. #1 Driven for months without power steering.
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    My 97 Grand Prix was driven for months without power steering. I purchased the car about a year and half ago for really cheap. I haven't driven it since I purchased it. I bought her for a project car or a fixer upper. Now, I'm going to start fixing her up because I finally have the time.
    The gentleman I bought it from told me that he was driving it for like 6 months without power steering. WOW.....Lol! I drove her around the block today and I didn't hear nothing, it was just hard to turn when I was driving slow. Then, I added fluid and it came out very quick, by the time I made it back from around the block the second time it was empty. It was leaking on the driver side.
    The gentleman also told me he changed the power steering pressure line prior to the 6 months of driving it but it didn't fix it, so I guess he just kept driving it like that.
    My question is what could of possibly got damaged? Rack and pinion, gear box, power steering pump, etc.....
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SK® 4T65E Transmission Shift Kit, 180* Thermostat
  2. #2 Re: Driven for months without power steering.
    St. Louis
    Well, since you don't have a gear box and it is leaking on the drivers side (the PS pump is on the pass. side) I'd say either a line at the rack is leaking or the rack itself is shot. Seeing as how it's a 97 and likely the original rack I'd be willing to bet that the rack is shot. Being driven w/o PS fluid that long isn't going to help the rack either. Best way to tell is if the leak is coming from the inner tie rod boot on the rack. If it's wet then I'd call it done. Time for a new/used AC Delco rack.
  3. #3 Re: Driven for months without power steering.
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    pump will be shot too after being dry that long. id do the rack, the pump, and the lines. 6 months is ALOT of neglect.
  4. #4 Re: Driven for months without power steering.
    new rack and pump time for sure. driving on a dead rack kills it for sure, same as a dry pump, dead ville
  5. #5 Re: Driven for months without power steering.
    May 2013
    Yea, lol that's what I was thinking.
    Is it a difficult DIY job......on a scale of 1 through 10.
  6. #6 Re: Driven for months without power steering.
    Mar 2012
    NC
    On a scale of 1-10 as DIY jobs go...I'd say a 3.
  7. #7 Re: Driven for months without power steering.
    this was my second time. this one only took like 2 hours this time. first time was longer, not sure why lol
    its drive way work. no need for a lift. im a lank and was able to reach the rack mounting bolts from the side of the car, only thing i went under the car for was to get the lines off/on.
    you put the car on jack stands, take the wheels off, take the tie rod ends off the knuckle, lower the frame a bit, then remove the bolt to the steering shaft, pop shaft off the rack, then lower the frame some more, then the lines come off and the 2 mounting bolts tot the sub frame and pop it out the driver side wheel well. the p/s pump lines are clipped to the rack as well as a wire. look for that and un hook em.
    if you have magnasteer dont forget to unplug that plug it back in.
    some will say to take the sway bar out to ad room, but the rack bolts were clear to get to for me. so i left it in place.
  8. #8 Re: Driven for months without power steering.
    May 2013
    Scotty, I luv the pics you post...Lol I was thinking about taking the sway bar out but if I don't need to I won't.
    Do you know if there is a how to write up on this? I looked and didn't see one. I was thinking about doing one.
    Also, thanks Scotty, you are a big help!
  9. #9 Re: Driven for months without power steering.
    May 2013
    Yea...As Scotty pointed out, it doesn't look like that difficult of a job.
    Thanks man!
  10. #10 Re: Driven for months without power steering.
    May 2013
    Does the steering pump come out with the rack and pinion?
  11. #11 Re: Driven for months without power steering.
    Mar 2012
    NC
    It can but it's more difficult to do it that way.
  12. #12 Re: Driven for months without power steering.
    May 2013
    So, what do you suggest to take out first? Steering pump or rack and pinion.....
  13. #13 Re: Driven for months without power steering.
    Mar 2012
    NC
    Take the pump out first...then remove the rack.
  14. #14 Re: Driven for months without power steering.
    May 2013
    Ok....I'm going to make a note of that.
    Thanks
  15. #15 Re: Driven for months without power steering.
    this covers the job pretty good. but its on a lift. you do it the same but with jack stands and a floor jack to lower the sub frame.
    this guy dont take the wheels off, you'll have to cause your working on the ground.
  16. #16 Re: Driven for months without power steering.
    St. Louis
    One very important thing to remember is to remove the clip from the power steering pump that connects to the rear knock sensor. If you remove the pump with this still in place you run a good chance of ripping out the wiring to the sensor, and that's not in a good place to get to either, lol.. Seen it happen a few times.
  17. #17 Re: Driven for months without power steering.
    May 2013
    That's a good video on this subject!
    Ok, I been looking around on the internet for a better deal than the parts store for a complete rack and pinion unit. I found this http://www.rockauto.com/catalog/more...103&cc=1256015
    Does anyone know about this site and there parts? Is this a good product and deal?
    http://www.rockauto.com/catalog/x,ca...2BSupercharged
  18. #18 Re: Driven for months without power steering.
    you got napa by you? search their on line store they have one on sale for 152.00 130 core, but you get that back, and its all local to you, no waiting for the mail man.
    i actually bought that rack, and it didnt show up at the store, so i got one from their local re builder for 20 bucks more.
  19. #19 Re: Driven for months without power steering.
    May 2013
    What store are you talking about?
  20. #20 Re: Driven for months without power steering.
    napa. know how man
  1. Stupid ZZP DP question driven by paranoia
    By Exile in forum General Tech Discussion
    Last Post: 12-07-2013, 03:40 PM
  2. Slowest automobile you've driven?
    By Hippo Machine in forum Off Topic Discussion
    Last Post: 11-18-2011, 01:09 PM
  3. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  4. Loose connection? Being slowly driven mad!!
    By jokyfo in forum General Tech Discussion
    Last Post: 05-10-2011, 01:59 PM
  5. Possible to change drive/driven sprockets in-car?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2008, 03:18 PM
