Thread: Front suspension creak
Results 1 to 7 of 7
  1. #1 Front suspension creak
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So while turning and going over a bump like pulling into a driveway something on the front of the car creaks. Sounds like the struts but don't know how ot could be them. They've only got a few thousand miles on them and mostly everything else is brand new on the front. All the mods are in my signature. I just hate driving around having a nice looking car that makes stupid noises.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: Front suspension creak
    I'd say strut mount.
    New parts do go bad quickly sometimes.
  3. #3 Re: Front suspension creak
    Buffalo, NY
    What part of the strut mount would I check to see if it's bad? iirc they are moog.
  4. #4 Re: Front suspension creak
    Buffalo, NY
    Also i put them together myself. Could it be something like I didn't tighten the strut to the mount enough or something similar? I used anti pogo washers on all 4
  5. #5 Re: Front suspension creak
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    I had the same noise in front end with my Eibach/KYB AGX setup. This was after 4 years after the installation. I replaced the mounts and that solved the problem. I used Moog mounts also.
  6. #6 Re: Front suspension creak
    Buffalo, NY
    Huh well that kinda sucks then. Not really looking forward to having to pull them and do all that work again. Maybe it'll wait until next spring. There will be no side effects of not changing them right away right?
  7. #7 Re: Front suspension creak
    St. Louis
    Shouldn't be, other than the front end sounding like sh*t, lol... I have the same issue when it gets cold out for some reason. Can't wait to replace the mounts and have a quiet front end again.
  1. front suspension
    By RyanL in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2015, 11:29 AM
  2. front suspension help!
    By CyxRyan in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2014, 01:01 AM
  3. Anyone put 97-03 front suspension on an 04?
    By Wakeboy1337 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2013, 08:30 PM
  4. loud noise from front suspension
    By runn141 in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2010, 08:39 PM
