Thread: Replacing rear struts in 02 GTP
Results 1 to 2 of 2
  1. #1 Replacing rear struts in 02 GTP
    Feb 2010
    Lincoln, Nebraska
    So, I got my car aligned and it fixed the steering wheel being way off... Now it seems to have amplified the rear struts squishiness. I reduced the air pressure and it helps, but they seriously need to be replaced b/c the back end hops around. And now on the interstate it rattles intermittently quite a bit. It feels like before a tire is going to blow out.
    Anyways, is there any tips I need to know in replacing the rear struts? Most videos I've seen show it as super straight forward and, might I say, EASY. I found Monroe Quick Struts which I plan to buy tonight.
    And what about the front struts? I need to do those too. But they are 100x less worse than the rear ones.
  2. #2 Re: Replacing rear struts in 02 GTP
    Feb 2013
    Missouri
    They are pretty straight forward, take the old one out, but the new one in. Are you sure you didn't break a rear sway bar or end link?
  1. Replacing struts??
    By malmar112 in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2016, 01:56 PM
  2. Replies: 20
    Last Post: 03-26-2013, 11:05 AM
  3. Replacing struts do I need Camber bolts???
    By dhdolphns in forum Brakes/Suspension/Chassis
    Last Post: 09-11-2012, 08:08 AM
  4. Replacing Cartridge in Front struts.
    By waytostupid in forum Brakes/Suspension/Chassis
    Last Post: 07-16-2012, 12:38 PM
  5. 2001 GTP - Replacing Struts - KYB GR2 plus other parts?
    By zguy in forum Brakes/Suspension/Chassis
    Last Post: 03-19-2012, 10:14 PM
