X2 on the spacers. I do not recommend going this route.
Many do this so they can remove and sell the calipers and they will still fit the F-Body's. If you drill and retap them they will only fit our cars from this point on, but if you decide to sell them, all it takes is a bracket to get them back to stock, no big deal.
I drilled and tapped mine, and reused the stock caliper bracket bolts from my Grand Prix with the rebuilt F-Bodys and have never had them come loose ever. I even installed them with no thread locker, not a problem to date with them.
While about every one I know who did the shim method had a caliper bolt loosen up, and fall out and the caliper will every time get damaged and will of course damage the rim. It always seems to be the top bolt from what I have seen, so as soon as you hit your brakes with a missing bolt, your other bolt now becomes a pivot, and the rim is what stops the caliper. It nasty when it happens.
~F~
