Thread: Rear springs
Results 1 to 19 of 19
  1. #1 Rear springs
    Banned
    CT
    Since the search function on all relevant wbody sites is horrendous......
    I'm looking for springs for the rear that'll raise or keep stock ride height, but also be stiffer.
    Similar to the pedders zero drop springs for GTO's.
    Need as much spring rate as possible without blowing $700 on coilovers.
    Would prefer to raise the rear an inch or so if possible.
    Any ideas?
  2. #2 Re: Rear springs
    I think the intrigue springs raise the rear up.
  3. #3 Re: Rear springs
    Dec 2012
    Where 4T65E's were born
    Well it may be a bit out of what you're looking for but the kyb replacement struts come with springs that are stiffer than stock, and raised mine up a good inch, inch and a half from where the old 113k rear struts were. Here's a comparison of springs if you're interested
    Sold.
  4. #4 Re: Rear springs
    Banned
    CT
    I'm thinking of going with the intrigue springs and a spring spacer to raise it an additional ~1.5"
    Should bring it up about 3" from where it sits atm.
    Or just throw a spacer on the vogtlands that are on it now to retain the higher spring rate.
  5. #5 Re: Rear springs
    Jun 2013
    Hollywood ,FL
    Which spacers you going to go with
  6. #6 Re: Rear springs
    Nov 2014
    BFE,Ohio
    just curious what spacer you went with i' want to do the same with my rear
  7. #7 Re: Rear springs
    Banned
    CT
    I never did it… just cable modded for the track.
    Still on the to do list though.
  8. #8 Re: Rear springs
    Enfield, CT
    04+ rear springs are the same as intrigues
  9. #9 Re: Rear springs
    hangover park IL
    if you don't like how high the front springs on our rear struts were for the turbo regal....you can use lowering front springs on the rear and get the really high spring rate but the nearly stock or only above stock height...ours was raised nearly 3 inches with comp G front springs on the rear struts
    ~James~ Psychotic Gearhead
  10. #10 Re: Rear springs
    Banned
    CT
    Now that sounds like something I can get behind.
    Right now I've got AGX/Vogtlands on the rear… Maybe just order up some front vogtland springs and put them on the rear.
    My aluminum coil overs on the front are awesome.
    The front air dam nearly drags on the ground when the back is cabled up.
  11. #11 Re: Rear springs
    hangover park IL
    id almost suggest OEM fronts with a coil cut off would probably be a good bit higher spring rate as well as only a little "donklift"
  12. #12 Re: Rear springs
    Never Never Land
    I know you said you weren't wanting to blow a bunch of money but you could make coils for the rear for not a whole lot honestly. You could make them yourself for under 200 bucks.
    Springs are roughly 40 a pop. $80
    Sleeves are about 20 a pop. $40
    Adjuster nuts are about 10 a pop. $20
    Top hats are about 10 a pop. $20
    Reuse your AGX's and mounts.
    So roughly 160 bucks plus tax and shipping. Should still be right at 200 or less.
    Just some food for thought.
  13. #13 Re: Rear springs
    Aug 2008
    so cal
    Has anyone ever done Vogtlands up front stock spring in the rear? Wonder how that would act.
  14. #14 Re: Rear springs
    Jan 2015
    Syracuse, NY
    I have a set of intrigue springs FS if anybody is interested. REAR
  15. #15 Re: Rear springs
    Enfield, CT
    Quote Originally Posted by BOOGIEMAN View Post
    What's your price?
  16. #16 Re: Rear springs
    Jan 2015
    Syracuse, NY
    $50. for the two. u ship. New are like $45 each
  17. #17 Re: Rear springs
    Enfield, CT
    mmmm I'm gonna have to pass because shipping plus the parts are gonna cost more than $60. I can get new oe rear springs for 04+ (which are exactly the same as intrigues) for $62 shipped. Thanks tho
  18. #18 Re: Rear springs
    Nov 2009
    PACNW
    I tried this with longer KYB struts for a Regal on the rear. Once I lowered the rear end down, it sat the same height as my '04 did before. Using 1.5 inch spacers got it higher. But you can feel the bumps in the road a bit more now.
    Adding the strut tower braces helped a bit in stiffening the front and rear suspension a bit too.
  19. #19 Re: Rear springs
    Mar 2013
    Norfolk va
    W- bday store has rear heightening and is heavier duty
    I think that's the route I'm going..
    Sent from my SCH-I535 using Tapatalk
  1. Rear strut/springs
    By danwilson1959 in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2014, 07:43 AM
