Thread: Dorman Trailing Arms are not symmetrical. Which side is which?
Results 1 to 17 of 17
  1. #1 Dorman Trailing Arms are not symmetrical. Which side is which?
    Oct 2011
    Toledo, OH
    The connecting bar isn't in the center like the stock ones. Is the bar closer to the wheel or not? Will it be clear when I go to install them, or does it not matter anyway?
    7"
  2. #2 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    I'd just assume that there must be a left and right printed on them, but maybe not.
    I'd say you want the bar further from the tire so it doesnt rub. So with the picture you have, the front one is the left side and the other is the right side but you need to flip it over.
  3. #3 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Oct 2011
    Toledo, OH
    There isn't a left/right, both are the same part number. Makes sense to put the bar away from the tire.
    7"
  4. #4 Dorman Trailing Arms are not symmetrical. Which side is which?
    Yup put them away from tire.. Worse case you'll swap then around if needed but I'm sure once you get them in place you'll figure out if they're on correctly or not.
    04 Comp G.
  5. #5 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    There is no left or right. Put the connecting bar to the inside of the car. GM starting making these so they could put wider profile tires on their cars.
  6. #6 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Pennsylvania, USA
    *facepalm* I put the bar closer to the wheel when I put mine on, and I have no clue as to why. It is for tire clearance a lewis mentioned. I'm about to replace my rear brake lines so I guess I'll flip them now in case I ever run wider tires or whatever.
    Quick question to anyone who's installed or replaced trailing arms, I know like most suspension parts you're supposed to torque them while the suspension is loaded. How did you guys go about that? I use low-profile hydraulic jacks and jack stands, and with my garage/basement floor being a bit uneven, I'm kind of uneasy jacking up the bottom of the arm to load it.
  7. #7 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Drive the car on ramps or stacked wood. Peek head under tighten done.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Pennsylvania, USA
    The damn ramps I got at a yard sale are too steep, I'll have to cut up some wood leading up to them to clear the rear bumper. Can't complain though, got them for $10 and they're still rust free.
    That's the route I'll go though, thanks for the tip!
  9. #9 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Apr 2012
    Dayton, OH
    Carefull with the wood, I did that then when the car decided to slam into reverse it shot 1 of the ramps out and my GP was flexing like a rock crawler.
    2012 F150 STX
  10. #10 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    we should start calling you TIM.......you didnt read a thing in this thread but the first post right?
  11. #11 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Apr 2012
    Dayton, OH
    Me? Says the guy bringing back a 5 month old thread :P
    Sent from BFE
    2012 F150 STX
  12. #12 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    no. someone must have deleted their post or something, wish I quoted it.
  13. #13 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by SpeedGrid
    I know its been awhile but how was the install process? did you have any problems when installing thse since you said they are not symmetrical. I ask because I am going to order a set myself and dont want to run into any issues with compatibility.
    Only issues is you have to take off the body side brackets, and those bolts like to break. Also the knuckle side nut is like 200 lbs of torque and the bolt was seized into the knuckle. I needed a blow torch and a sledgehammer for it.
    7"
  14. #14 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Speedgrid brought it back.
    Timussaur has a nice ring to it.
  15. #15 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Apr 2012
    Dayton, OH
    Oh, i never saw his post before he deleted it.
    Hey now, I'm not as bad as Tim was.
    Sent from BFE
    2012 F150 STX
  16. #16 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Any proof?
  17. #17 Re: Dorman Trailing Arms are not symmetrical. Which side is which?
    Apr 2012
    Dayton, OH
    No but, you know me well enough right? I have good intentions.
    Sent from BFE
    2012 F150 STX
  1. dorman control arms?
    By Jakegday in forum General Tech Discussion
    Last Post: 08-14-2011, 03:48 PM
  2. Trailing Arms
    By shawngtp in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2010, 08:56 AM
  3. just an fyi--trailing arms
    By quinnp12 in forum Brakes/Suspension/Chassis
    Last Post: 02-03-2010, 12:38 AM
