Thread: swaybar and trailing arm questions.
Results 1 to 8 of 8
  1. #1 swaybar and trailing arm questions.
    SE Level Member Silversurfer Gio's Avatar
    Huntington station new york
    OK, so so I've searched the hell out of these two subjects and havent really come across anything definitive, so I decided to just flat out ask in my own thread. Question 1- what size sway bars would a 2000-05 Monte carlo ss(non-supercharged) have? question 2, will trailing arms from a gxp bolt directly into my 2001 gtp? Been doing some junk yard searching for some good cheap suspension upgrades and just wanted to make sure I'm looking for the right stuff.
    2001 GTP special edition 2dr-3"downpipe,plogs,4 inch cai,dynomax exhaust,3.5 pulley,msd 8mm wires,flipped db's, gmpp front and rear sways,gxp trailing arms,gmpp stb's,kyb struts,wbs lateral arms.
  2. #2 swaybar and trailing arm questions.
    Question #2 is yes
    Edit: also the Monte Carlo SS that came with the ls4 also have the same bars that you can use.
    04 Comp G.
  3. #3 Re: swaybar and trailing arm questions.
    I have a third question(again searched the hell out of it with no results). What do the gxp trailing arms look like? Are they tubular, are they rectangular? Are they worth putting on over the stock stamped ones? I don't want to get the dorman arms or the umi or bmr arms. Trying to keep the car as GM as possible.
    Sorry Im kinda weird like that.
  4. #4 Re: swaybar and trailing arm questions.
    Enfield, CT
    I like to keep the car as GM as possible too. Tubular is definitely worth the upgrade over the ****ty stamped ones. The original GXP trailing arms were tubular but the replacements are boxed. If you see any tubular T/A, then they are most likely GMPP
  5. #5 Re: swaybar and trailing arm questions.
    Thanks for the info man. I appreciate it
  6. #6 Re: swaybar and trailing arm questions.
    Figured I'd do a follow up, I got a set of trailing arms out of one of the gxp's from the junkyards by my house, neither one had tubular trailing arms. But the arms that they did have were still pretty strong, its a solid square rod, so I cleaned them up, painted them and bolted them right in. 30 Bucks well spent.
  7. #7 Re: swaybar and trailing arm questions.
    Arizona
    Sadly my trailing arms are originals to my knowledge there square ones....maybe some Gxp got tubulars but I have yet to see one
  8. #8 Re: swaybar and trailing arm questions.
    Dec 2012
    troll land
    Solid square rod? Sounds like dorman
  1. Swaybar Sizes
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2024, 05:51 AM
  2. swaybar install
    By GTP GTP GTP in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2012, 05:34 PM
  3. 01 grand prix trailing arm questions
    By sasquatch094 in forum Brakes/Suspension/Chassis
    Last Post: 07-03-2011, 01:47 PM
  4. Swaybar Brackets...
    Last Post: 11-13-2009, 01:07 PM
