Thread: Abs issues?????
Results 1 to 5 of 5
  1. #1 Abs issues?????
    Jan 2014
    Kentucky
    IF YOU ARE SEARCHING DOWN SENSOR OR WIRING ISSUES I LEARNED THE HARD WAY HOW TO TEST THE WIRING AND WHEEL SENSORS ALL IN ONE TEST.
    I HAVE BEEN TRACKING DOWN THIS LITTLE ISSUE FOR SOME TIME NOW. I HAVE A SCANNER THAT DOES ABS. IT WAS GIVING ME RIGHT FRONT SPEED SENSOR SUPPLY SUBFAULT, SO I WAS TROUBLESHOOTING RIGHT SIDE FRONT WHEEL.
    I REPLACED FRONT BEARING HUBS BOTH SIDES WHICH IT DID NEED DUE TO ROARING WHILE AT HIGH
    SPEEDS. THIS DIDNT FIX THE PROBLEM WITH ABS LIGHT. I THEN REPLACED HARNESS ON THE RIGHT SIDE, SAME THING ABS LIGHT STILL ON. I THOUGHT WHAT ELSE COULD IT BE. I GOT OUT THE WIRING DIAGRAMS ON THE ABS. I FOUND THE WHEEL SENSOR WIRES ON THE EBCM MAIN PLUG. IF YOU LOOK VERY CLOSE THEY ARE NUMBERED.
    IN MY CASE MY( RF NUMBER 4 & 5),( RR 2 & 3),( LF 20 & 21), (LR 22 & 23). I GOT OUT MY METER AND TESTED 2 & 3, IT WAS LIKE 650 OHMS, 4 & 5 WAS 660, AND 22 & 23 WAS 656, 20 & 21 WAS 2.354 OHMS.
    I THEN KNEW THE PROBLEM WAS ON THE LF INSTEAD OF THE RF. I GOT UNDER MY CAR AND PULLED THE WIRES OUT OF THE PLASTIC LOOM, ONE OF THE WIRES WAS BROKE INHALF.
    AFTER I REPLACED THE HARNESS ON THAT SIDE NO MORE ISSUES.
    I DONT KNOW WHAT WOULD CAUSE MY SCANNER TO GIVE A RIGHT FRONT CODE WHEN THE ISSUE WAS THE LEFT FRONT. THAT IS WHAT GOT ME SO CONFUSED. IF YOU SCAN AND GET A CERTIN WHEEL SPEED SENSOR FAULT IT MIGHT BE A GOOD IDEA TO DO THIS SIMPLE LITTLE TEST, IT DOSENT TAKE A FEW MINS BEFORE YOU START BUYING PARTS.
    I REALLY HOPE THIS WILL HELP SOMEONE OUT SAVE THEM SOME TIME AND MONEY, THIS SITE AND THE INTELLIGENT MEMBERS ON THIS SITE HAS HELPED ME OUT ALOT, SO I THOUGHT I WOULD TRY AND GIVE SOMETHING BACK. HOPE IT HELPS
  2. #2 Re: Abs issues?????
    Helping is great.
    But a word of advise, use some paragraphs broseph.
  3. #3 Re: Abs issues?????
    This
    04 Comp G.
  4. #4 Re: Abs issues?????
    Nov 2011
    NY
    Lol... My eyes!
  5. #5 Re: Abs issues?????
    Jan 2014
    Kentucky
    LOL!! My bad, I didn't realize how hard on the eyes it was until I had already posted it, also next time I will not do all caps either. I tried to break it up some. Thanks
  1. Key Fob Issues
    By i3abydoll in forum General Grand Prix Discussion
    Last Post: 05-07-2015, 11:14 PM
  2. few issues help!!!
    By Jory Johnson in forum General Grand Prix Discussion
    Last Post: 06-15-2012, 03:33 PM
  3. EGR issues. Need help
    By IMPALADAKID in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2012, 10:49 AM
  4. Any issues?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 12-27-2009, 06:42 PM
  5. 04 GT 2 issues I need your help with...
    By skubasteve! in forum General Tech Discussion
    Last Post: 12-04-2009, 09:57 AM
