Thread: Removing bolts to replace wheel hub bearings
Results 1 to 10 of 10
  1. #1 Removing bolts to replace wheel hub bearings
    Jan 2014
    Woodstock, GA
    I bought some Timken wheel hub replacements for my front end.
    I'm having a hell of a time getting the 3 bolts out for the replacement. Any tips on what has worked? Tried heat, breaker bar and the usual suspects. The bolts are just in a tough spot...can't get my electric impact wrench on them. Thinking about using a chisel and hammer but it's going to be tough to get that in there as well.
  2. #2 Re: Removing bolts to replace wheel hub bearings
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    Either soak them in pb blaster or some liquid wrench for a bit
    Edit : also try turning the wheel a bit may give you some more room
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  3. #3 Re: Removing bolts to replace wheel hub bearings
    I've just used MAP gas then a 6 point socket, sometime you need a swivel socket. Helps to turn the hub all the way to towards the right to gain more room.
  4. #4 Re: Removing bolts to replace wheel hub bearings
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    I've always thought they were fairly easy to get at....For the top one, sometimes the CV shaft boot gets in the way depending on if its the original axle or a replacement. I assume you've already got the rotor off, if not take it off and you can get at the other side of the bolt with PB blaster, its a through hole so you can see the other side of the bolt with the rotor off. Use a deep well socket with a 6" extension and it shouldn't really be an issue. Best of luck!
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  5. #5 Re: Removing bolts to replace wheel hub bearings
    Quote Originally Posted by Dtrick22 View Post
    I have insider info that you used a different method to so these and axles in the past.
  6. #6 Re: Removing bolts to replace wheel hub bearings
    Either a deep or shallow with an extension to get past the CV and they aren't usually too bad. If you can't get them that way, pop the balljoint, pull the axle out of the knuckle and you have a clear shot at them.
    BTW a 1/2" actually fits those bolts better than a 13mm.
  7. #7 Re: Removing bolts to replace wheel hub bearings
    Aug 2012
    Iowa
    I just replaced mine not too long ago and I found that turning the steering wheel all the way to one side made it easier to get to. Also, using a shallow socket with an extension and swivel joint really helped me out for the top one.
  8. #8 Re: Removing bolts to replace wheel hub bearings
    Feb 2013
    Woodbridge NJ
    I have done several of these bearings. An impact makes it super easy. But like said above turn the wheel for easier access. Use a 6 point 13mm socket (very important) with a floppy extension. For the top bolt place a jack under the control arm and jack it up. Makes for much more room to get to that bolt. I never had to use heat or penetrant oil even when using a ratchet. These bolts are torqued to 118 ft/lbs so they are quite tight.
    Don
    2004 GT1
  9. #9 Re: Removing bolts to replace wheel hub bearings
    SWPA
    I had zero issues getting to mine. A quick smack of the rather with my hand and it broke the bolts free.
  10. #10 Re: Removing bolts to replace wheel hub bearings
    Donating Users timboku's Avatar
    Montgomery, IL
    6 point 1/2 inch drive with a 2 inch extension on a breaker bust the loose all the time. It clears the cv boot for the top as well. Turn wheel to left, get top one and lower one, turn wheel to right, get the other lower one. I have done over 10 from rusty 97s to 07. Pb on the threads help as well.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  1. Replacing the crankshaft, main, and rod bearings without removing heads?
    By OcalaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2013, 11:57 PM
  2. Wheel Bearing Bolts - Replace?
    By BlackGS in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2013, 06:28 AM
  3. How to replace Supercharger Bearings
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 08-09-2012, 02:08 PM
  4. Wheel Bearings?
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2010, 08:05 PM
  5. Removing collector flange bolts without breaking anything.
    By BackInBlack in forum General Tech Discussion
    Last Post: 07-25-2008, 12:31 AM
