Thread: Strut tower braces
Results 1 to 17 of 17
  1. #1 Strut tower braces
    SE Level Member Prixer97's Avatar
    Jul 2011
    Fargo, ND
    What STB's do you guys recommend? Are aftermarkets better then gmpd's?
  2. #2 Re: Strut tower braces
    Oct 2011
    Toledo, OH
    Don Rome brackets plus GM bars used to be the way to go. Dunno if he still makes brackets though.
    7"
  3. #3 Re: Strut tower braces
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    I have zzp front & rear & think they are definitely worth the money. I've read that the best stbs use all 3 bolts for each tower, but I often remove mine to make room for tinkering, & the 2 bolt design means I don't have to remove all 3 strut top bolts, worry about the alignment. But, I may get a front stb from arrautmotorsports because its adjustable and I'd like to get my 2.5* camber down to 2*.
    The problem that's causing the issue is right there between the seat and steering wheel. It's you
  4. #4 Re: Strut tower braces
    Arizona
    Your stb does not affect alignment whatso ever. And get Zzp ones don't bother with gmps as they were never engineered to bolt to an aluminum bracket and then the strut tower.
  5. #5 Re: Strut tower braces
    Quote Originally Posted by industrialfish View Post
    http://www.drcustomparts.com/
  6. #6 Re: Strut tower braces
    GT Level Member TheDarkAngel's Avatar
    Oct 2013
    Iowa
    I'm in the process of making my own
    First car- 1999 Buick Regal LS (Sold)
    Current ride- 2000 Grand Prix GT (The Dark Angel) DIY Intake, flipped bushings, visual stuffs, lowered on Eibachs, Topswap loading...........
  7. #7 Re: Strut tower braces
    Oct 2011
    Toledo, OH
    Bio, his site is still up but for some reason I am remembering he no longer worked in the machine shop he was at, and wasn't making them anymore. I could be completely wrong though.
    7"
  8. #8 Re: Strut tower braces
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    I just ordered a pair of the front brackets from him. I received mine. So he may have left over product or is still making them.
  9. #9 Re: Strut tower braces
    Sep 2012
    Casper Wyoming
    Quote Originally Posted by TheDarkAngel View Post
    They look super simple to make.
  10. #10 Re: Strut tower braces
    Dec 2012
    troll land
    Personally id rather just drill the holes......
  11. #11 Re: Strut tower braces
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    I've had ZZP and now have BMR. Only reason I changed was because the BMR are thicker and got them used for basically the same price as the ZZP bars. But between the 2 there's not much difference at all.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  12. #12 Re: Strut tower braces
    Pennsylvania, USA
    The difference between the GMPP with Don's brackets and the 3 bolt ones, like from ZZP, isn't nearly worth the added cost IMO. These cars are boats, the biggest handling improvements you'll get are from lowering with some quality gas charged struts (Bilsteins are great) and matched springs, and good, grippy tires.
  13. #13 Re: Strut tower braces
    Nov 2011
    Chicago
    Quote Originally Posted by 91parkave View Post
    Anytime you remove ALL of the strut tower top plate bolts you risk changing your alignment. My zzp, & the gm, stb does not affect alignment what so ever. The purpose of the design of the adjustable stb is to pull in or push out the strut top plate, which affects alignment.
  14. #14 Re: Strut tower braces
    Buffalo, NY
    Why would you want to push in or out the strut towers? I did my BMR and didn't get an alignment after. I doubt they moved at all since the car was on the ground.
  15. #15 Re: Strut tower braces
    Arizona
    Quote Originally Posted by Mr D View Post
    What? no your holes in your strut tower arent slotted to begin with STB's are adjustable to push out not pull in on the strut tower by bolting onto the strut mount. If you had custom camber plates i could see your point but wbody arent adjustable from the top unless you were to slot them youreself.
  16. #16 Re: Strut tower braces
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Does ZZP make some that the fit the GXP?
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  17. #17 Re: Strut tower braces
    Arizona
    Nah you'd have to either custom make one or use the don Rome brackets plus gm stb
  1. Strut tower braces
    By GTPJIM in forum Wanted To Buy - Parts
    Last Post: 09-25-2013, 02:44 AM
  2. Strut Tower Braces
    By MBruneaux in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2011, 12:48 AM
  3. Strut Tower Braces
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2010, 06:03 PM
