will the front rotors and calipers off a 07 police impala be a direct bolt on for a 1999 grand prix
Should be. If they are the same as the stock 06+ Monte/Impala rotors. Grab the rotors, calipers, bracket and bolts. Should be a direct bolt-in. You will have to bend the retaining tab for the brake hoses out a bit to be sure the lines do not get stretched. Just check your tire clearance once the are mounted turning lock-to-lock and be sure they don't rub either.
every thing works except the caliper bracket bolts to spindel are a little to long
