Thread: 2008 GXP Bilstein Struts
Results 1 to 8 of 8
  1. #1 2008 GXP Bilstein Struts
    SE Level Member buckslayer's Avatar
    valparaiso,IN
    Can you adjust the these struts to soften the ride any. I had a 2007 and rode perfect now I have this 2008 and rides very stiff.
  2. #2 Re: 2008 GXP Bilstein Struts
    Arizona
    nope. if its "stiff" might wana double check tire pressures and verify your control arms move up and down easily.
  3. #3 Re: 2008 GXP Bilstein Struts
    valparaiso,IN
    Brand new Bridgestone potenza's 30psi. And everything seems ok. Just not as smooth as my 2007.
  4. #4 Re: 2008 GXP Bilstein Struts
    Arizona
    Was your 07 a GXP as well?
  5. #5 Re: 2008 GXP Bilstein Struts
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Possibly they have been replaced. When they are replaced Bilstein has a stiffer version than stock and a softer version than stock. Maybe yours has the stiffer version. If you can get a part # off of them, that might help.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  6. #6 Re: 2008 GXP Bilstein Struts
    Potenza's are a very stiff tire to begin with, they arent fun to put on 18's.
  7. #7 Re: 2008 GXP Bilstein Struts
    Nov 2011
    NY
    I have Portenza's on 18's and they hold corners like rails! No hydroplaning ... But have worn pretty fast though is my only complaint.
  8. #8 Re: 2008 GXP Bilstein Struts
    valparaiso,IN
    Not to sure cause I just bought the car in January but pretty sure they are original. I have have my 2007 gxp still . Bought back from the insurance company. A drama yeah I wouldn't want any other tire on this car then the potenza's. ... but man the ride is definitely not the same. And I no for a fact nothing was done to my 2007 before I got it and it even sounded better.
  1. Bilstein Coilovers
    By 91parkave in forum Brakes/Suspension/Chassis
    Last Post: 10-07-2014, 06:07 PM
  2. Bilstein HD?
    By Akuch26 in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2013, 10:07 AM
  3. Bilstein Rear Struts...
    By Alsafi92 in forum Wanted To Trade
    Last Post: 01-29-2013, 04:11 PM
  4. agx vs bilstein
    By 06PONTGP in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2012, 08:59 PM
  5. Bilstein offered for 97-03??
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2010, 10:30 AM
