Thread: Time to replace everything
Results 1 to 20 of 21
  1. #1 Time to replace everything
    Aug 2012
    Iowa
    Hey guys. I've had my 05 Comp G for a year and a have now and have put nearly 40k miles on it since then. I'm getting around 170,000 and the suspension needs upgraded. I have a pretty good tax refund coming (since I can write off all my mileage for work ) and I want to upgrade my whole suspension. I don't need performance parts since it's my daily driver, but I need something that is going to last 25k miles a year. I would like to pretty much upgrade everything and get it all done at once so I don't have to worry about replacing something else a few months down the road. My ABS/Traction Control/Stability Control lights are on because of the front left wheel so I'm going to replace the hub while I'm at it. If you guys could help me out and basically give me a list of things I should get and good brands I would greatly appreciate it. Thanks in advance.
  2. #2 Re: Time to replace everything
    Nov 2012
    Madison
    Well for starters, are you doing the work?
    The AC delco FE3 factory struts for your car are about $110 each....just for struts.
    Monroe mounts another $100+.
    You could get KYB GR2 struts for closer to $250 for all 4. Monroe mounts $100+
    You should be able to reuse your rubber isolators and springs unless they are beat.
    You could get whatever quick struts(AC/Delco from rockauto $145 each) for the back but they don't make them for the front.
    Then you have Moog sway bar end links another $100.
    So KYB GR2s --part# 339089 x2 & #334228 x2
    Monroe mounts -- part# 902968 x2 & #902969 x2
    Moog sway bar end links -- part# K80852 x2 & #K6662 x2
    If you do it yourself those parts will be around $500. (more if you want the factory AC/Delcos/FE3s)
    and then you have the lower control arms 110 each and.....
  3. #3 Re: Time to replace everything
    Apr 2013
    White Lake
    If you plan on doing it yourself then I would go to rockauto and choose between Monroe, KYB, or ACDelco. They seem to have the lowest price compared to auto parts store's around my area. You can get the complete assembly for the rear's but for some odd reason the front's dont... For the front you could keep your old springs or get new and buy the strut and strut mount then go to your local auto parts store and rent a spring compressor. Plenty of video's on youtube to give you an idea what the compressor is and how to use it "easy".
    Now on to your hub,... I would first check to see if the plug/wire's have corrosion on them and clean them off to see if that will fix your problem. That happen to me on one hub but the other one I had to replace so try it before you replace it. Also check your stabilizer bar bushing which are on your sway bar to see if that has any play.
    Hope this helps out a little! =D
  4. #4 Re: Time to replace everything
    Mercer, Pa
    If your going to keep the car, do the inner and outer tie rod ends, lower control arms sway bar end links all at the same time.
  5. #5 Re: Time to replace everything
    Aug 2012
    Iowa
    I do plan on doing the work and I am most likely going to keep the car until it dies because it's a nice car to drive back and forth to work. So how long should a job like this take? Keep in mind I do all the routine maintenance myself and have done quite a bit of work on it so far so I know my way around it pretty well. Thanks for the advice so far.
  6. #6 Re: Time to replace everything
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    I was in the same boat as you last year, here's a list of what I used with CompG Springs and rear sway bar (All from Rock Auto)
    Excel-G 339015 Front Struts (06+ Style, FE4 Spec)
    Excel-G 339148 Rear Struts (06+ Style, FE4 Spec)
    Monroe Strut Mounts
    Dorman Front Swaybar
    06+ Style LCA's (Dorman)
    New hubs at all 4 corners (Timkin)
    New brakes (Brakemotive)
    Also installed new inner and outer tie rods.
    WELL worth the effort and $$$
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  7. #7 Re: Time to replace everything
    Nov 2012
    Madison
    OK that's with the swap over to eliminate the bastard 04-05 style sway.
    What I don't get is the KYB FE4 spec?? thought only Bilsteins accomplished that. Did you mean FE2?
  8. #8 Re: Time to replace everything
    Oct 2012
    Pinckney, MI
    The KYB's I used are spec'd for an Impala or Monte Carlo with the FE4 Special Handling Package. More details in this thread: http://www.grandprixforums.net/threa...-with-KYB-tech
    So far I'm VERY happy with this setup.
    -Rob
  9. #9 Re: Time to replace everything
    Aug 2012
    Iowa
    How much did all of that cost and how long did it take to do?
  10. #10 Re: Time to replace everything
    Oct 2012
    Pinckney, MI
    Parts were around $1100 total for everything. Just looked at my receipt and I forgot to mention that I also purchased new CV Shafts as well.
    Took me about 5 hours working in my driveway to swap everything out.
    -Rob
  11. #11 Re: Time to replace everything
    Aug 2012
    Iowa
    Quote Originally Posted by RivMan View Post
    -Rob
    Your setup does sounds pretty good. Is there any way you can give me the part numbers for everything you bought. That would be really helpful and I would greatly appreciate it.
  12. #12 Re: Time to replace everything
    Oct 2012
    Pinckney, MI
    Quote Originally Posted by tachasmo View Post
    Here's what I bought from RockAuto. The Tie rods are Moog from a local parts store.
    No Vehicle Specified
    KYB 339015 Strut $ 60.79 $ 0.00 2 $ 121.58
    KYB 339148 Strut $ 68.79 $ 0.00 2 $ 137.58
    2004 PONTIAC GRAND PRIX 3.8L V6 Supercharged
    CARDONE SELECT 661255 (66-1255) CV Half Shaft Assembly $ 44.79 $ 0.00 1 $ 44.79
    CARDONE SELECT 661256 (66-1256) CV Half Shaft Assembly $ 46.89 $ 0.00 1 $ 46.89
    MONROE 902969 Strut Mount $ 15.31 $ 0.00 1 $ 15.31
    MONROE 902973 Strut Mount $ 20.99 $ 0.00 2 $ 41.98
    MONROE 902968 Strut Mount $ 15.31 $ 0.00 1 $ 15.31
    TIMKEN HA590092 Wheel Bearing & Hub Assembly $ 81.79 $ 0.00 2 $ 163.58
    TIMKEN 513179 Wheel Bearing & Hub Assembly $ 90.79 $ 0.00 2 $ 181.58
    2006 PONTIAC GRAND PRIX 3.8L V6 Supercharged
    DORMAN 520165 (520-165) Control Arm $ 37.79 $ 0.00 1 $ 37.79
    DORMAN 927100 (927-100) Stabilizer Bar Assembly $ 78.79 $ 0.00 1 $ 78.79
    DORMAN 520166 (520-166) Control Arm $ 37.79 $ 0.00 1 $ 37.79
    Discount $ -46.15
    Shipping Ground $ 86.92
    Order Total $ 963.74
    I've never had issues with the Cardone Select (New) shafts, but I've used the Cardone A1 (Reman) shafts, and wasn't happy with them.
    -Rob
  13. #13 Re: Time to replace everything
    Aug 2012
    Iowa
    Discount $ -46.15
    -Rob
    Did you buy new springs or did you re-use the ones on your vehicle?
  14. #14 Time to replace everything
    Mercer, Pa
    New CV shafts? The new ones are cheap Chinese. I would not change OEM CV shafts unless I had to. I still have one original at 208,000 miles.
    I bought a JK (Morad) when I replaced.
  15. #15 Re: Time to replace everything
    gardner,mass
    Quote Originally Posted by sseilmnop View Post
    This^ since swapping to the cheap a1 cv that every store sells ive returned and replaced each side twice in a year. Good thing they have a lifetime warantee but still ill eventually swap them for stocks or buy something better.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  16. #16 Re: Time to replace everything
    Mercer, Pa
    The only better is stock. Zzp has a stage 3 or something which is a modified OEM but I don't think they are worth it.
  17. #17 Re: Time to replace everything
    Mercer, Pa
    You can save the old axles because you bought the new Chinese axles!
    Don't loose them!
  18. #18 Re: Time to replace everything
    I would have went with Moog lcas. I've heard the Dormans arent as good.
  19. #19 Re: Time to replace everything
    Oct 2012
    Pinckney, MI
    I used CompG springs off of my wrecked donor car.
    I've had great luck with the Cardone New CV's, and with a lifetime warranty, I'm not to worried about hanging onto some blown out stockers.
    I ran the Dorman LCA's on my 99 Regal for ~100k miles with no issue at all. If these fail, I'll probably get Moog, but so far they're nice and solid.
    -Rob
  20. #20 Re: Time to replace everything
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    I give a bunch of suspension tech pointers on my website http://www.getoverkilled.ca/wbodytech.html
    I'd pick up the 06+ Impala police recall LCAs, they're nice and inexpensive for OEM quality stuff and they have the sway bar connection point. This will then allow you to pick up a GMPP or Dorman front sway bar upgrade, and give you lots of options on struts including KYB AGX which are my favorite or 97-03 Monroe Quick Strut assemblies (the 97-03 springs will lower your 04+ ride height 1/2", FYI).
    If you do AGX struts and whatever springs, use the part numbers on my website to build new strut assemblies rather than breaking down your old struts to salvage a few small parts. You may just find that Canuk Motorsports springs are the best way to go for the price, even if you don't necessarily want lowering springs, and again I recommend 97-03 units because they have the corrected rear spring heights to fix sag, their 04+ or any other W-Body springs do not.
    I believe you can get OEM outer tie rods from GM with no grease fittings, sealed factory install units, my preference over aftermarket.
    Timken, Raybestos, Moog/National or SKF wheel bearings, I've used all with success. Main thing you must must do is ensure the axle nut is torqued to spec, not just hammered home with an impact or it will lead to premature bearing failure.
    Email all inquiries to willoverkill@gmail.com!
  1. Change LIM gasket what else should I replace at the same time?
    By 71gs3504sp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-21-2014, 04:51 PM
  2. Time to replace LIM
    By WhiteLightningGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2013, 09:00 PM
  3. Time to replace brake lines
    By lght1 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2010, 07:32 PM
  4. If I replace stereo, how does computer know time?
    By ponyfool in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2009, 09:16 PM
  5. If I replace stereo, how does computer know time?
    By ponyfool in forum General Tech Discussion
    Last Post: 03-17-2009, 09:53 PM
