Thread: Ball Joint and Sway Bar End Link?
Results 1 to 14 of 14
  1. #1 Ball Joint and Sway Bar End Link?
    Apr 2012
    Illinois
    After going to just tires for some new rubber and an alignment, the tech told me I need a new drivers side ball joint and sway bar end link. He showed me the play in the tire and it seems legit, except for the price. I am going to replace the whole lower control arm and not deal with the rivets, but my main concern is do I need to replace the sway bar end link? Any other advice or tips I should know?
    Moog Lower Control Arm
    Moog Sway Bar End Link?
    Thanks in advance.
  2. #2 Re: Ball Joint and Sway Bar End Link?
    Yeah those Moog LCAs are good.
    End links are cheep, I would replace both sides.
  3. #3 Re: Ball Joint and Sway Bar End Link?
    Apr 2012
    Illinois
    both lca's or just the end links. thanks for the extremely quick reply!
  4. #4 Re: Ball Joint and Sway Bar End Link?
    Dec 2012
    Where 4T65E's were born
    Both, replacing things in pairs is a good practice. Because if you don't the other side parts will miss the old ones and self destruct right after replacing just one lol. Wheel bearings are the most common for doing that.
    Sold.
  5. #5 Re: Ball Joint and Sway Bar End Link?
    Apr 2012
    Illinois
    Oh they get lonely and depressed. Another quick question what about lube for the bushings and ball joint.
  6. #6 Re: Ball Joint and Sway Bar End Link?
    Dec 2012
    They should be non serviceable, so no need to worry about grease.
    Sold.
  7. #7 Re: Ball Joint and Sway Bar End Link?
    Apr 2012
    Illinois
    One more question, whats the difference between these two. From what I see one comes pre-made and has different bushings and the other is a "kit".
    http://www.rockauto.com/catalog/more...775&cc=1317113
    http://www.rockauto.com/catalog/more...834&cc=1317113
  8. #8 Re: Ball Joint and Sway Bar End Link?
    Dec 2012
    If you have a 98 like in your forum name then you want part #K5342. I've never seen that white bushing style before.
    Sold.
  9. #9 Re: Ball Joint and Sway Bar End Link?
    Apr 2012
    Illinois
    According to moog's website they're polyurethane bushings.
    http://www.moog-suspension-parts.com...rod=MOOG-K5342 - Part # K5342
    http://www.moog-suspension-parts.com...d=MOOG-K700527 - Part # K700527
  10. #10 Re: Ball Joint and Sway Bar End Link?
    Dec 2012
    Well with the blue ones, if you tighten them right down til it stops there's no way there's any flex in those bushings. They get hard when they compress. Just put a pair on a buick yesterday, I like em.
    Sold.
  11. #11 Re: Ball Joint and Sway Bar End Link?
    The Moogs I got you had to grease the ball joints. They did not have any grease in them.
    Sent from A Galaxy Far Far Away........
  12. #12 Re: Ball Joint and Sway Bar End Link?
    Dec 2012
    The moog lca's? That's possible, aftermarket's usually do on the ball joint, the end links are not a ball and socket style.
    Sold.
  13. #13 Re: Ball Joint and Sway Bar End Link?
    Yup, I think the dormans even have greasable ball joints in their lcas.
  14. #14 Re: Ball Joint and Sway Bar End Link?
    Dec 2008
    Lawndale, CA
    There are a couple version of moog LCA's. The one's with grease fittings are more expensive. The cheaper priceed one's don't have them. The dormans also don't have them.
  1. How to get ball joint off and new one on
    By Bigheadedon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2013, 03:07 PM
  2. 97 ball joint
    By jc71corvette2 in forum Introductions/Noob Questions
    Last Post: 10-02-2013, 11:25 AM
  3. Ball joint help
    By geetee in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2011, 05:23 PM
  4. ball joint maybe?
    By Jakegday in forum General Tech Discussion
    Last Post: 10-04-2009, 11:15 AM
  5. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
