Thread: 04 GTP Rear camber out -2.5+
Results 1 to 9 of 9
  1. #1 04 GTP Rear camber out -2.5+
    SE Level Member mckillin's Avatar
    Ontario, Canada
    Hey guys...
    2004 Pontiac Grand Prix GTP Comp G. 175km
    Replaced front monroe quick struts last year. They didnt have a quick strut for rear so just did shock.
    Just got new tires put on, alignment is wayyy out. Been to 2 places. One was the tire shop and 2nd is
    strictly alignment shop. -2.5 on camber both sides (one almost 3)
    He says 2 camber bolts per side will bring it back to -1 where it should be.
    Wondering if i should do the springs also or just leave them... He says they arn't broke or anything.
    I have no problem replacing it if it needs done but making sure its getting fixed properly.
    He said that almost looks like a lowering spring.
    Thanks guys
    mckillin
  2. #2 Re: 04 GTP Rear camber out -2.5+
    you need camber bolts. buy them on line, install them yourself, then go back to the shop for the alignment, or your back tires will wear out on you.
  3. #3 Re: 04 GTP Rear camber out -2.5+
    Ontario, Canada
    Awesome, thanks buddy.
  4. #4 Re: 04 GTP Rear camber out -2.5+
    have them slot the struts instead.
    or just replace the springs with a set that isn't sagging like hell and get it realigned.
  5. #5 Re: 04 GTP Rear camber out -2.5+
    Ontario, Canada
    Those springs are pretty shot? Ive never seen 4 sitting on each other like that
  6. #6 Re: 04 GTP Rear camber out -2.5+
    i just noticed that they are stacked 4 deep. if the back end passes the 3 bounce rule, put new springs in the back maybe. cheaper then new struts id think.
  7. #7 Re: 04 GTP Rear camber out -2.5+
    SE Level Member FASGP's Avatar
    Toronto ON
    My 05 did the same. Suggest you put in some replacement springs, and if you still have camber issues, slot upper hole in the strut and use a camber bolt kit in the bottom.
    Vtec...All the lag and none the turbo...it's like waiting for bad sex
  8. #8 Re: 04 GTP Rear camber out -2.5+
    Yea I would throw in some replacement springs or find some lower mile ones
    04 Comp G.
  9. #9 Re: 04 GTP Rear camber out -2.5+
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    fixing the springs will fix the camber but will also but the vehicle back to the correct ride height...if you care about that and how weight distribution effects braking, handling and front steering geometry.
    2004 comp g
  1. Rear Camber Question
    By ccrane in forum 5.3L V8 (LS4)
    Last Post: 01-07-2014, 10:59 PM
  2. 2.0 camber????
    By bandits grand prix in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2011, 09:30 AM
  3. GM rear camber fix
    By gtx3800 in forum Brakes/Suspension/Chassis
    Last Post: 03-28-2011, 06:41 AM
  4. What wears to cause the classic rear camber issue?
    By PCweber in forum General Tech Discussion
    Last Post: 07-15-2010, 04:02 PM
  5. Negitive camber in the rear???
    By shawngtp in forum Brakes/Suspension/Chassis
    Last Post: 11-29-2009, 12:09 AM
