Thread: GP GXP Front End Sway (rough roads)
Results 1 to 11 of 11
  1. #1 GP GXP Front End Sway (rough roads)
    Jan 2014
    louisiana
    Hello all, new to the forum deal, but am a long time Pontiac enthusiast and owner (74 grandville, 85 bonneville, 99 grand am) of Pontiacs and have currently acuired an 08 GP GXP. Haven't ever driven or riden in once until i purchased this one last week, but have been searching the web in regards to one of the concerns i have with this vehicle. I noticed when on rough rural roads, those that have ruts, etc from tractors and big trucks, that the car has a tendency to follow these. It's an eye opener and makes you have to hold on. Anyone exerienced in these issues have any particular advice on what to look out for or possibly change or upgrade? Front tires seem to wear a little more on the inside and a little tread life left, but are nearing the end of their life span. Previous owner put Nexen S3000, i believe. Any advice would be appreciated.
  2. #2 Re: GP GXP Front End Sway (rough roads)
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    Sounds like its in need of an alignment
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  3. #3 Re: GP GXP Front End Sway (rough roads)
    Nov 2013
    Des Moines, IA
    Quote Originally Posted by cheeseburger03 View Post
    Welcome to the forum as well !
    2007GPGTSC
    " sad thing is "
  4. #4 Re: GP GXP Front End Sway (rough roads)
    Jan 2014
    louisiana
    Alignment seems pretty good, although I could be wrong, but its tracks very well on smooth roads, with of course the slight pull to the right.
  5. #5 Re: GP GXP Front End Sway (rough roads)
    So tires are pretty much junk unless you're going to autocross the car everyday. I wouldnt doubt that its a helping reason as to why it follows grooves/ruts in the road.
    Inside wear is somewhat common on the GXP, they have 18x8 front and 18x7 rear for rim size. Because of the 2 different size tires, its hard to get perfect wear and even harder if the tires up front or in the rear are directional. They will spin the same way their whole life and can wear quicker, also if the camber is off on any corner it will wear the inside edge faster.
    Some new tires and atleast check the alignment and you should notice a difference.
  6. #6 Re: GP GXP Front End Sway (rough roads)
    I live here. DirtDog's Avatar
    Jun 2012
    Heck I have damn near perfect alignment and mine will follow grooves and all. Always has done that. One thing I've done and has helped considerably with it is ZZP LCAs and a gmpp sway bar. Since doing that it tightened things up a lot. I have coil covers to install as well...but don't have time.. but 91parkave said that it made a huge difference with his.
    Also any mods or anything to the car. How many miles
    Sent from my DROID RAZR using Tapatalk
  7. #7 Re: GP GXP Front End Sway (rough roads)
    GT Level Member fisher580's Avatar
    Jan 2012
    Dyersville, Iowa
    any low profile tire will always try to follow grooves in the road due to less give in the sidewalls.
    2001 Grand Prix GTP Coupe - Black-SOLD
    -SOLD
    2006 Grand Prix GXP - That Purplish dark red color
    -FWI, DiabloSport Trinity, and Trans. Cooler - - 6.8 @ 208 mph LOL
  8. #8 Re: GP GXP Front End Sway (rough roads)
    Arizona
    Has nothing to do with low profile. Get you alignment checked out and wider directional tires will follow grooves depending on grade and type of road your traveling on.. Mine does it as well. Also make sure your sway bar end links are good to go as well.
  9. #9 Re: GP GXP Front End Sway (rough roads)
    Jan 2014
    louisiana
    We'll, I'd gotten Allied tire here to check the alignment and the first thing off the top was that they would not be able to do it because of the negative camber in the rear. The jerks wanted to charge me $69 for each camber bolt kit plus install fee to put them in. TotL was like $238 with alignment. Had to pause on that for the moment.
    Front tires are directional, those nexens as previously mentioned.
  10. #10 Re: GP GXP Front End Sway (rough roads)
    Jan 2014
    louisiana
    Away bar end links seem tight too. Is taken off the front wheels the other day to check out the brakes and stuff to make sure everything was good. I'd picked up some autozone rotors and pads to get rid of the brake wobble from high speed stopping as we'll.
  11. #11 Re: GP GXP Front End Sway (rough roads)
    Jan 2014
    louisiana
    Damn spell check...
  1. Front sway bar help
    By rhenuset in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2013, 04:33 PM
  2. GMPP front and rear sway w/ front STB
    By FordMan77 in forum General Grand Prix Discussion
    Last Post: 10-31-2012, 03:04 PM
  3. Front Sway Bar
    By 1SICKGP in forum General Tech Discussion
    Last Post: 09-01-2010, 10:20 PM
  4. Clunking from front end on smooth roads 2005 GXP
    By glss421 in forum 5.3L V8 (LS4)
    Last Post: 05-14-2010, 08:19 PM
