Thread: Rear Shocks squeaking Grand Prix 2008
Results 1 to 9 of 9
  1. #1 Rear Shocks squeaking Grand Prix 2008
    Mar 2013
    Canada
    I had all my shocks replaced last year and today I notice when I go over speed bumps in shopping malls there is this squeaking noise coming from the back shocks. I open up my trunk and push down and I clearly can hear the squeak coming from the rear shocks. Its been warm last few days and now its getting cold again anything to do with the weather? Normal driving on the road with dips in the road I dont hear anything only reason why I heard it is because I went over a speed bump. Can I spray anything on it?
  2. #2 Re: Rear Shocks squeaking Grand Prix 2008
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    Cold weather makes rubber hard as H*LL probably your squeaking
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  3. #3 Re: Rear Shocks squeaking Grand Prix 2008
    Mar 2013
    Canada
    so its normal then?
  4. #4 Re: Rear Shocks squeaking Grand Prix 2008
    check the back sway bar bushings. maybe they are the squeak.
  5. #5 Re: Rear Shocks squeaking Grand Prix 2008
    Mar 2013
    Canada
    Anything I should look at when looking at the sway bar bushing? I do hear the sound in my trunk when I push down on the back. Will see if I can upload a audio with the sound
  6. #6 Re: Rear Shocks squeaking Grand Prix 2008
    see if you can get your head under the car while someone pushes in down. listen look for the squeak.
  7. #7 Re: Rear Shocks squeaking Grand Prix 2008
    Mar 2013
    Canada
    I hear the squeak in the trunk in the corner where the shocks are I will look at it again.
  8. #8 Re: Rear Shocks squeaking Grand Prix 2008
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    Check for cracks in the bushing to. Mine were all cracked ip
    2001 sliver gtp her name is Reagan
  9. #9 Re: Rear Shocks squeaking Grand Prix 2008
    Mar 2013
    Canada
    Here is the noise of the squeak its coming from the passenger rear side
    https://www.dropbox.com/s/146w6e0onf...ing%20%231.wav
    Sent from my SGH-I337M using Tapatalk
  1. I need a set of rear shocks
    By TEK310 in forum Southwest
    Last Post: 06-10-2013, 09:02 PM
  2. Rear Shocks - Trunk sits too low
    By Bologna in forum General Tech Discussion
    Last Post: 06-06-2012, 12:49 PM
  3. Grand Prix GXP Shocks/Struts Options - HELP!!
    By extreme in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2011, 08:29 AM
