you could probably piece together stuff yourself and get a better end product, but it won't be cheaper.
x2. The Monroe Sensetrac Quick Struts seem to be good quality, good ride, in the W-Bodies I've been in with them. Stock ride height obviously but if you have 22s you likely have a 27" or taller overall height, I doubt you want to lower.
When I used to piece together lower springs and strut assemblies, I would use Monroe parts to complete everything such as the rubber isolators, accordion boots and upper strut mounts. The Monroe upper mounts are one of the few that actually position the top of the strut shaft in the correct centered position, never had an issue with Monroe mounts, can't say the same with other brands I tried.
