Thread: Trac Off Light on
Results 1 to 6 of 6
  1. #1 Trac Off Light on
    Sep 2012
    Cedar Rapids, Iowa
    My Trac Off light is on my DIC and won't go off by hitting the Trac button. The ABS light is also on on the dash. Anyone know what the problem might be.
  2. #2 Re: Trac Off Light on
    Sep 2012
    Cedar Rapids, Iowa
    I should also mention that I had recently replaced the wheel hub/bearing with the speed sensor and that the breaks seem to be working fine.
  3. #3 Re: Trac Off Light on
    Feb 2013
    37.295091, -121.930053
    Dumb question did you plug it back in? Also the connection maybe not sending the correct signal to the computer
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: Trac Off Light on
    Sep 2012
    Cedar Rapids, Iowa
    Yup plugged it back in, even double checked it. Everything else works on the DIC (avg. MPG, oil life, gallons of fuel used, etc.) and even tried it with a spare one and got the same result.
  5. #5 Re: Trac Off Light on
    Feb 2013
    Check how many volts its sending. Almost sounds like a bad connection to me
  6. #6 Re: Trac Off Light on
    Get it scanned and see what code is throwing
  1. ABS light and Trac Off light come on at same time
    By kking89 in forum Brakes/Suspension/Chassis
    Last Post: 10-26-2013, 04:16 PM
  2. abs light on, trac ctrl light off, what does this mean?
    By tcman49 in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2013, 03:04 PM
  3. ABS light on, Trac Off light on, New hubs all around
    By tdm571 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2011, 07:44 PM
  4. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  5. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
