Thread: Rubbing noise from rear passenger tire area.
Results 1 to 3 of 3
  1. #1 Rubbing noise from rear passenger tire area.
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    I was driving when all of a sudden a rubbing noise started by the rear pass. tire. Before this happened I was having some clanking noise in the same area every time I hit a bump. Anyone with this issue before? I am thinking its part of the suspension and bushings of some sort just giving out from old age. I also reversed and cut the wheel and a popping noise came from same area like metal on metal. I will check it out asap. Thx in advanced.
  2. #2 Re: Rubbing noise from rear passenger tire area.
    take the wheel off and look for rubbing in the wheel well. also check for a broken strut spring. if the tire is rubbing it will also show signs of it rubbing.
    id jack it up and spin the wheel before taking the wheel off, listening for any sounds.
  3. #3 Re: Rubbing noise from rear passenger tire area.
    also push and pull on the wheel when its jacked up if its moving left and right or top to bottom, somethings not right. could be a hub even.
  1. Clunking from passenger side tire area
    By DJE in forum Introductions/Noob Questions
    Last Post: 04-21-2013, 07:08 PM
  2. Rubbing noise
    By cruzn in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2011, 09:56 PM
  3. Odd noise / rubbing
    By Elitemonkie in forum General Tech Discussion
    Last Post: 11-06-2010, 08:06 AM
  4. 'Rubbing' Noise when Backing Up
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 10:41 PM
  5. Rubbing noise from front left tire
    By zeppelinrocks18 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2009, 05:45 PM
