Thread: Need Guidance: Wiring up new ABS/Trac Sensor Cable (vehicle side, not hub side)
Results 1 to 10 of 10
Threaded View
  1. #3 Re: Need Guidance: Wiring up new ABS/Trac Sensor Cable (vehicle side, not hub side)
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    thanks for posting the part number. I was looking for that harness.
    unless you have a special open barrel crimping tool, the metal crimps that come with the kit will be no use to you. I would used heat shrink butt connectors and put the black heat shrink that comes with the kit over the butt connectors. You could also solder it in.
    that is the proper way to repair this. splicing in regular stranded wire into an abs harness is a temporary fix.
  1. AC blows Ice Cold on the Passengers Side and warm on the Drivers Side.
    By rynoman03 in forum General Tech Discussion
    Last Post: 08-08-2011, 11:18 PM
  2. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  3. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
