Thread: Rear Brakes
Results 1 to 16 of 16
  1. #1 Re: Rear Brakes
    SE Level Member GXPrunner06's Avatar
    Jan 2013
    Romulus, MI
    So I had a rough morning. I went to Autozone to get the bolts and they're two different times. So I bought both in return the other one. Then after doing that I found out that the inner brake pad had fallen off. So the sucky part is that my wife had already left for work this morning. So I rode my sons bike up to Advance Auto and picked up new brake pads . So after getting this I completed I went and double checked the passenger side. And guess what... Those bolts were coming loose 2. So I replace the pads on that side and bleed all brakes . I have had quite a busy morning but I'm glad my car is running good. One last question. are the washers for the banjo bolts that going to the caliper reusable? I had to disconnect the caliper on the driver side in order to get the piston back in properly. The brakes aren't leaking so I'm not sure.
    Sent from my SCH-I535 using Tapatalk
    2006 GXP| Pioneer 8400 | LED Interior Lights | Daily Driver | Diablosport 91 octane tune/DOD disabled
    2002 GTP 40th Anniv.| ubend delete | zzp 1.0 pcm | K&N full intake
  2. #2 Re: Rear Brakes
    Jan 2013
    Romulus, MI
    Quote Originally Posted by GXPrunner06 View Post
    So I had a rough morning. I went to Autozone to get the bolts and they're two different types for the rear. So I bought both and returned the other one. Then after doing that I found out that the inner brake pad had fallen off. So the sucky part is that my wife had already left for work this morning. So I rode my sons bike up to Advance Auto and picked up new brake pads . So after getting this completed I went and double checked the passenger side. And guess what... Those bolts were coming loose 2. So I replace the pads on that side as well tightened everything and bleed all brakes . I have had quite a busy morning but I'm glad my car is running good. One last question. are the washers for the banjo bolts that go in to the caliper reusable? I had to disconnect the caliper on the driver side in order to get the piston back in properly. The brakes aren't leaking so I'm not sure.
  1. GXP Rear Brakes Help
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 01-16-2013, 07:32 PM
  2. rear brakes
    By ray03gtp in forum Brakes/Suspension/Chassis
    Last Post: 01-16-2011, 02:38 PM
  3. GXP Rear Brakes
    By TMC in forum General Tech Discussion
    Last Post: 05-11-2009, 11:46 AM
  4. What rear brakes fit?
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2008, 11:46 AM
