Thread: abs light on, trac ctrl light off, what does this mean?
Results 1 to 7 of 7
  1. #1 abs light on, trac ctrl light off, what does this mean?
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    On and off now for about 2 weeks my abs light has been on, the traction control light off and the anti-lock brakes seem to kick in every once in awhile for a few seconds for no good reason.
    Is this a bad sensor problem, bad bearing/wheel problem or something else?
    any help would be appreciated.
    this is on a 2001 grand prix gtp that is in great condition and has been properly maintained over the years.
    Thanks
    Terry
  2. #2 Re: abs light on, trac ctrl light off, what does this mean?
    GTP Level Member buickman104's Avatar
    NYC
    I had the exact same symptoms. It turned out to be a wire to a wheel speed sensor was shorting out. had to carefully pull it apart and resolder it and insulate it.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: abs light on, trac ctrl light off, what does this mean?
    St. Louis
    Sounds like the harness/wiring to the ABS sensor is going bad. The wires often corrode pretty far up the connection and break. I had to replace the harness section from the sensor to the main loom connection up on the subframe. Not sure if the 01's have it separate or not. I know in later years that seemed to disappear.
  4. #4 Re: abs light on, trac ctrl light off, what does this mean?
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Check your ABS wire connections and the harness. I had the same issue. Looked, and the connection to the front passenger hub was hanging down. Reseated the connection and attached it properly to the hub, and haven't had the issue since.
    Short version - check the wires.
  5. #5 Re: abs light on, trac ctrl light off, what does this mean?
    Aug 2011
    'Merica
    yes to all of the above. I had this issue on my 03 too. replaced the harness and all was well.
  6. #6 Re: abs light on, trac ctrl light off, what does this mean?
    Apr 2011
    Palm Coast, Florida
    Where exactly on the car should i be looking for the wire connections and harness?
    thanks
    Terry
  7. #7 Re: abs light on, trac ctrl light off, what does this mean?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Jack up the car and pull off one of the front wheels and check right where the wire connects to the hub. You will be able to see it. Mine gave me the same issue 2years ago. I just said f**k it and pulled the abs fuse after I ran a stop sign because the abs randomly came on. Pulled into the next parking lot to take it out and still to this day haven't felt like fixing it. Always hated ABS anyways.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  1. ABS light and Trac Off light come on at same time
    By kking89 in forum Brakes/Suspension/Chassis
    Last Post: 10-26-2013, 04:16 PM
  2. ABS light on, Trac Off light on, New hubs all around
    By tdm571 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2011, 07:44 PM
  3. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  4. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  5. my low trac is lit and so is the abs light
    By beast55 in forum General Tech Discussion
    Last Post: 06-27-2009, 01:23 PM
