Bum bum bummmm
Bum bum bummmm
I'd be in
1/2 inch thick x 8" x12" inch aluminum sheet how much would you charge if I sent it to you yo water jet?
Yer anal virginity
Well ****. I plan to install my front coil overs and rear suspension stuff this coming weekend
Alignment done car has a noticeable sharper turn in, she needs helper springs and maybe its time for shorter springs . I did get my stb back on and functional.
did you by chance get measurements of those openings in that plate?
Also as an update had to run back through and re tourqe the bolts now that everything's settled in. Also had to make a ride height adjustment. Somehow the passenger coilover was slightly higher. So now all is done, no I'll issues to report on these and I may have found the camber plates of a more correct size to fit in the factory holes so no drilling of the body should be required of these
http://m.ebay.com/itm/141173611966?nav=SEARCH
need also slot to slot dimensions to be able to confirm your other dimensions please
i meant measure slot to slot iD/OD, not the length of yer pecker....
Working on another project straight up spherical bearing stock mounts with removable bearings .
i was kinda looking at the same thing for the TR but with the spherical moved 1" inboard and laying back the strut/welding on reinforcements
problkem im having is that the upper mounts curved and alum plate dont like that...the zzp junk is 1/4" steel and heavy as hell...sigh
