Thread: Went to Les Schwab for an alignment.... need your guys help
Results 1 to 20 of 27
  1. #1 Re: Went to Les Schwab for an alignment.... need your guys help
    GTP Level Member
    Oct 2011
    Raleigh, NC
    You can do it a lot cheaper also. They are both easy to do, he** even I did them .
    1997 Red GTP 182000 miles stock
  2. #2 Re: Went to Les Schwab for an alignment.... need your guys help
    Sep 2013
    Meadville, PA
    Get everything checked by a real mechanic before you start replacing stuff. Wheel bearings whine and grind when they are going bad. Have you heard anything different going down the road?
    If the bearing hub assembly does need replaced, doing so is within the capabilities of the average home mechanic with access to an air compressor, a decent range of sockets and whatnot, and a fair amount of patience (or friends with beer). Tie rod sleeve is pretty easy to see if it needs replaced. Got a hole or tear in it? Replace it. If not, leave it the heck alone.
    Don't go back there. Look like a bunch of useless rip off artists to me. If you were around me, I'd send you to my alignment guy. He only complains about tires......
  1. How's my alignment look?
    By LS1GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2013, 07:45 PM
  2. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  3. Alignment
    By dsh1106 in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2011, 10:39 AM
  4. Alignment
    By matt5112 in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2010, 03:51 AM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
