The larger problem will still be the mismatch between the coil spring rate and the dampening rate of the strut... They need to be matched in order to work correctly. In other words, the GR-2's are not the answer. It may work for a little bit, but will wear out and leave you wanting more... Proper investment in coilovers and matched struts will run ya around a grand for the front alone.
