Thread: Front brakes from a 2006 GP on a 2003?
Results 1 to 20 of 27
  1. #1 Front brakes from a 2006 GP on a 2003?
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Is this even considered an upgrade? If so, is it completely plug and pray, or is there anything that needs modding?
  2. #2 Re: Front brakes from a 2006 GP on a 2003?
    It really wouldnt be an upgrade at all.
    Using a better pad on a quality rotor is a better idea.
    Or you can do a F-body upgrade or a GXP upgrade, but you'll need 17's to run GXPs.
  3. #3 Re: Front brakes from a 2006 GP on a 2003?
    Might as well just get the 00-05 impala caliper brackets and rotors. You'd get larger rotors, and keep your existing caliper which means it costs less and it takes less time as you don't need to bleed the brakes.
    But you probably need new brake fluid anyways.
  4. #4 Re: Front brakes from a 2006 GP on a 2003?
    Dec 2008
    Lawndale, CA
    Don't forget the calipers from an 06+ monte SS/ impala SS. They are larger and dual piston and bolt right up.
  5. #5 Re: Front brakes from a 2006 GP on a 2003?
    04+ brakes are quite a bit bigger. I'd say about an inch. You'll need the rotors, calipers, and brackets.
  6. #6 Re: Front brakes from a 2006 GP on a 2003?
    Theyre not an inch. The bracket only upgrade is larger.
  7. #7 Re: Front brakes from a 2006 GP on a 2003?
    St. Louis
    Quote Originally Posted by The Guz View Post
    Don't forget the calipers from an -6+ monte SS/ impala SS. They are larger and dual piston and bolt right up.
    ^This^. Just did this on my 00 GT and I'd have to say it's one of the best upgrades I've done. Bolted right up. Slap some new front lines on it, bend the line bracket out about 1 1/4" from where it currently sits (check for tire clearance from lock to lock) and bleed all 4 corners. Done. I've exchanged my fluid in the past and got away with using exactly 2 pints to get it clear again and the fronts bled. If you haven't changed fluid in a while (or ever) then I'd grab at least a quart.
    With the Wagner ceramics it seems to be worthwhile. I had to actually "test" them out today when a minivan cut me off and I had to stomp the brakes. I was surprised by how fast it shed speed and didn't freak out the ABS. Nice and controlled.
  8. #8 Re: Front brakes from a 2006 GP on a 2003?
    The rotor is close to an inch bigger
  9. #9 Re: Front brakes from a 2006 GP on a 2003?
    97-03 GP:
    04-08 GP:
    00-05 Impala:
    Based on that, there is zero reason to go with the 04+ caliper and rotor unless you get a red hot deal on the calipers. Buying the brackets is cheaper and easier as you don't have to bleed the brakes.
    So on the numbers game: 00+ Impala would be 0.98" larger. 04-08 GP would be 0.75". If three quarters is an inch, then 98% is two.
    The 06+ Impala upgrade is:
    Or 11.92" in 'murican.
    The 06+ Impala upgrade is the dual pot caliper. It offers the same braking force as the F body upgrade, yet it bolts on without spacers or tapping the bracket. Downside is more limited pad options, thinner rotor and iron instead aluminum caliper. The iron caliper could actually be a benefit as it won't clamshell like the F body calipers eventually will.
    Also since I finally made a spreadsheet for calculating brake force and bias, I'm going to run the GP stock options and upgrades and let Dave post them in his big brake thread. Yes, I'm going to take a simple average of the rotor diameter instead of using the OD.
  10. #10 Re: Front brakes from a 2006 GP on a 2003?
    Ehh .75" close enough
  11. #11 Re: Front brakes from a 2006 GP on a 2003?
    The rotor diameter is for heat capacity anyways, not stopping force.
    The size of the pot in the caliper and the coefficient of friction of the pad are the main influences in stopping force calculation.
  12. #12 Re: Front brakes from a 2006 GP on a 2003?
    Not worth it when you start to price out parts. Your better off doing one of the other upgrades.
    04 Comp G.
  13. #13 Re: Front brakes from a 2006 GP on a 2003?
    Like a junkyard 12" bracket/00-05 Monte rotor setup.
  14. #14 Re: Front brakes from a 2006 GP on a 2003?
    Mar 2013
    Manitoba, Canada
    So, the `06 Impala rotor, caliper, and bracket is a 100% bolt on? No drilling, no tapping, no bushing, just bleeding?
  15. #15 Re: Front brakes from a 2006 GP on a 2003?
    Yes. Dont forget pads from that car as well.
    Your car is old enough that youd want new hoses as well.
  16. #16 Re: Front brakes from a 2006 GP on a 2003?
    Dec 2012
    troll land
    The sway bar on the monte/impala is an upgrade too
  17. #17 Re: Front brakes from a 2006 GP on a 2003?
    Mar 2013
    Manitoba, Canada
    Okay, going for broke here, any chance the rear brakes are an upgrade?
    Sent from my Galaxy Nexus using Tapatalk 2
  18. #18 Re: Front brakes from a 2006 GP on a 2003?
    Dec 2012
    troll land
    Same brakes on back steering rack on monte is tho 13:2 to1 ratio
  19. #19 Re: Front brakes from a 2006 GP on a 2003?
    St. Louis
    The only rear brake upgrade that I'm aware of is the GXP rear brakes. I think those bolt on 100% with no adaptations/drilling, etc... Read the big bad brake thread to be sure on that one.
  20. #20 Re: Front brakes from a 2006 GP on a 2003?
    Dec 2012
    troll land
    Yup
  1. New front brakes and now a squeaking noise up front
    By Trann14 in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2013, 08:45 PM
  2. new front brakes
    By hilldog27 in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2013, 03:01 PM
  3. 07 GXP Front Brakes
    By Fireof59 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2010, 05:14 PM
  4. Front brakes
    By MikeB91 in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2010, 07:48 PM
  5. ls1 brakes up front
    By stanggreg90 in forum Brakes/Suspension/Chassis
    Last Post: 04-12-2010, 12:32 PM
