Thread: GP Suspension Bounce & KYB GR2's
Results 1 to 6 of 6
  1. #1 GP Suspension Bounce & KYB GR2's
    Cambridge, Ontario Canada
    Car is getting some nasty suspension bounce at times, enough on big bumps to scrap the exhaust a fair bit. I am thinking of getting some KYB GR2's to stiffen the ride up & stop the bounce (assuming bounce is from blown stockers). Pretty cheap option too from ZZP for $240 for all 4. I will also be replacing the rear strut tower mounts as well. Opinions?
    2005 E55 - stock
  2. #2 Re: GP Suspension Bounce & KYB GR2's
    do all mounts when you are doing them.
  3. #3 Re: GP Suspension Bounce & KYB GR2's
    Fronts were done about 10K miles ago, just a strut issue up front now i think
    2005 E55 - stock
  4. #4 Re: GP Suspension Bounce & KYB GR2's
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Just make sure to check the strut towers for rot
  5. #5 Re: GP Suspension Bounce & KYB GR2's
    Quote Originally Posted by addzradd View Post
    All mint except for the ****ty passenger rear, getting that fixed next week
    2005 E55 - stock
  6. #6 Re: GP Suspension Bounce & KYB GR2's
    Dec 2008
    Lawndale, CA
    Check the prices at rockauto. You will probably save a little more there than ZZP. As stated don't forget the mounts. Monroe makes some good mounts. I am not sure if you are lowered or not but you could also get some anti-pogo washers.
  1. headlights bounce around
    By fremmy182 in forum General Tech Discussion
    Last Post: 02-09-2013, 11:27 AM
  2. Annoying headlight bounce
    By GTLGDP in forum General Tech Discussion
    Last Post: 02-08-2013, 02:27 PM
  3. RPM's bounce while coasting
    By ItHurtz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2012, 12:46 AM
  4. OEM style headlight bounce
    By BoostnBlackGTP in forum Visual/Body Modifications
    Last Post: 01-02-2011, 12:31 PM
  5. Head light bounce
    By stlunatics2oo3 in forum Visual/Body Modifications
    Last Post: 12-13-2010, 03:12 PM
