Thread: shaking under braking - ok to replace just rotors or must pads be replaced as well?
Results 1 to 5 of 5
  1. #1 shaking under braking - ok to replace just rotors or must pads be replaced as well?
    May 2013
    detroit
    03 gp gt - daily driver. i have hawk eps brake pads which have worked well for me and appear to have plenty of life left in them. i am experiencing very bad shaking under light braking and it appears to be time to replace the rotors.
    can i replace the rotors without also doing the brake pads? or is this generally not recommended.
  2. #2 Re: shaking under braking - ok to replace just rotors or must pads be replaced as wel
    SE Level Member rhenuset's Avatar
    winnipeg
    Its not the best idea to replace just the rotors. Did you just replace the pads?
  3. #3 Re: shaking under braking - ok to replace just rotors or must pads be replaced as wel
    May 2013
    detroit
    Quote Originally Posted by rhenuset View Post
    no; they prob have 50k/3yrs on them (both rotors and pads replaced at the same time during last maintenance) but i am a very light braker and visual inspection looks to be about 50% of pad-life left. the rotors themselves don't visually look too bad but one or more def has some warping due to recent shaking/vibrations under braking.
    they are expensive pads and this is just my daily driver so i'd prefer not to incur the additional cost of (pricy) HPS pads unless i have to.
  4. #4 Re: shaking under braking - ok to replace just rotors or must pads be replaced as wel
    winnipeg
    Do the rotors for sure and look around a bit for pads on sale.
  5. #5 Re: shaking under braking - ok to replace just rotors or must pads be replaced as wel
    If its a daily there is no need for hawk pads.
    I'd get some Adaptive one (ADO) from napa and some new rotors.
  1. New rotors/pads
    By Macca in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2013, 09:16 PM
  2. Shaking and braking
    By Scoty in forum Brakes/Suspension/Chassis
    Last Post: 01-31-2013, 08:57 AM
  3. Good rotors/pads?
    By red97gtpcoupe in forum Brakes/Suspension/Chassis
    Last Post: 08-29-2012, 08:51 PM
  4. Primechoice rotors and pads
    By TheBeastGTP in forum Brakes/Suspension/Chassis
    Last Post: 08-17-2010, 08:30 PM
  5. Rotors and pads
    By GMPUNK in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 09:33 PM
