Thread: both ABS an TRC OFF light is on
Results 1 to 4 of 4
  1. #1 both ABS an TRC OFF light is on
    Jul 2013
    ohio
    ok i have a 2000 gtp and both the ABS light and the TRC off light came on today. i drove it to work at 7am this morning an on my break i was cleaning the dash on door panels..jus wiping them down bored really. but any ways i went to leave at 3pm an i noticed the TRC light was in the off position and the (ABS) light came on and stayed on. i thought i might of just pressed the off button on the TRC but i pushed it again an the light still stayed on. i pressed it again an held it in this time an nothing light was still on. i recently did my breaks about a couple weeks ago so im not sure if i put them on weird or if whats going on. not sure were to start so any advice would b great thanks for reading.
  2. #2 Re: both ABS an TRC OFF light is on
    abs trac off lights are usually hub related, jack up the car and test each wheel for movement buy pushing and pulling the top of the tire, if it moves the hub is bad.
    if you cant find a bad hub go have the car scanned at a shop. that will direct you to the problem.
  3. #3 Re: both ABS an TRC OFF light is on
    I'd get it scanned first, then replace which bearing is bad.
    Minimal WB play is alright, because no sense in replacing a bearing that hasnt failed enough yet.
  4. #4 Re: both ABS an TRC OFF light is on
    Banned
    Jan 2013
    Colorado
    check the fuse
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  3. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  4. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
