Thread: Vibration at 70 mph
Results 1 to 8 of 8
  1. #1 Vibration at 70 mph
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    Ok.. I have a 2001 GT and it wasn't a concern really but I'm going to PA soon and will be doing more then 70mph at times I'm sure.. Anyway I figured it was one of my rear tires so I just went and got 2 used but good condition and replaced them balance etc just for the trip.. I do 70 and bang it's still there now what is curious about it is after 70 the more I hit the gas the more it vibrates BUT if I let off on the gas cruising at say 80 it doesn't vibrate bad but if I just feather the throttle it starts again which makes me think it's got something mechanical to blame.. Any ideas?
  2. #2 Re: Vibration at 70 mph
    Could be a cv joint. I'd look over the front suspension really good though.
  3. #3 Re: Vibration at 70 mph
    Mar 2013
    Staten Island, NY
    Yea I was thinking CV joint to.. I'm just ticked I wasted money on tires for no reason lol I thought it was a high speed wobble but I was wrong
  4. #4 Re: Vibration at 70 mph
    SE Level Member wilke's Avatar
    May 2013
    Minneapolis, Minnesota, United States
    hey at least you have 2 better tires.
    I have the same issue, can't figure it out. Let me know please if anything comes up. Thank you!
    - John
  5. #5 Re: Vibration at 70 mph
    could be a warped brake rotor too.
    or shot suspension parts.
  6. #6 Re: Vibration at 70 mph
    Mar 2013
    Staten Island, NY
    Quote Originally Posted by wilke View Post
    - John
    Will do!
  7. #7 Re: Vibration at 70 mph
    Mar 2013
    Staten Island, NY
    I'm not quite sure why but I drove the car today and was on the highway cruising pretty quick expecting to feel the wobble when I hit around 70 and I look down and I'm doing 80 no wobble! So first thing I did was slow the eff down cause the speed limit in NY is 55 lol but yea I'm not sure if there is a problem and hopefully soon I will get to my mechanic and check it out I had to go because when I make a sharp right turn I hear a crunch not sure if that is related but we will see.. BTW Wilke did you rotate you're tires or check balancing on them?
  8. #8 Re: Vibration at 70 mph
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    I'm getting the same vibration in the rear. So far, I've had the tires rotated and balanced. I've changed the rotors and pads. I've upgraded to the Dorman trailing arms and the GMPP sway bar. I'm still getting the vibration in the rear. I'm not sure how it could be the CV joint and not feel anything in the steering wheel. The only thing left are the wheel bearings and track bars/lateral links until I have a brand new rear end. I've done the rear bearings on a different GP and don't look forward to heating them out of the knuckles because I know I'll need to. Are the BMR's the only upgrades there?
  1. Vibration
    By RICHEYSGTP in forum Brakes/Suspension/Chassis
    Last Post: 11-04-2012, 12:58 PM
  2. Vibration?
    By mattstansbury in forum General Tech Discussion
    Last Post: 08-29-2012, 10:34 PM
  3. Vibration
    By Klutch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-26-2009, 02:52 PM
  4. Odd Vibration
    By VGPGT in forum General Tech Discussion
    Last Post: 04-15-2009, 04:18 PM
  5. Vibration
    By silvertip in forum General Tech Discussion
    Last Post: 04-09-2009, 09:09 AM
