Thread: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
Results 1 to 20 of 36
  1. #1 Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    GT Level Member des19's Avatar
    May 2011
    Ontario
    I recently put on my summer wheel set up and my driver side rear rubs when I hit bumps. It is loud and obvious that it rubs when this happens. Weird thing is its only the one wheel doing this. My tire got chewed up pretty bad. Am lowered on ssc/fe3. Is there any quick way to fix this or will I need to roll the fenders? Would rather not roll them.
  2. #2 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    May 2011
    Ontario
    also tires do not rub unless hit a bump or turn hard etc..
  3. #3 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    Easy/cheap route would be to roll your fenders.
    04 Comp G.
  4. #4 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    May 2011
    Ontario
    looks like its the only way i can go
  5. #5 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    if only one is rubbing versus the other it sounds like your alignment isn't even on both sides.
  6. #6 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    GTP Level Member joshv's Avatar
    canada
    my drivers side was getting chewed and my pass side stayed fine. lowered on ssc aswell. got my fenders rolled 50 bucks later no issues. wish i did that b4 buying new tires.. save urself the hassle and roll em !
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  7. #7 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    Omaha, NE
    Did you get an alignment when you put the springs on? If its not the alignment, you might have bent suspension components.
  8. #8 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    May 2011
    Ontario
    never got an alignment could be it but doubt it
  9. #9 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    Jan 2009
    Tallahassee, FL
    You'd be surprised. What's the offset of the wheels?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #10 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    May 2011
    Ontario
    Quote Originally Posted by Sandman View Post
    +38mm
  11. #11 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
  12. #12 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    May 2011
    Ontario
    go in and have them check your alignment.
    so I guess i should first start with a wheel alignment before rolling fenders?..note only the one wheel rubs when bumps are hit
  13. #13 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    Jan 2009
    Tallahassee, FL
    Since you lowered your car and didn't get an alignment anyways...you need one.
    77 Morris Garage B
  14. #14 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    exactly..
  15. #15 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    Omaha, NE
    And if the alignment isn't the problem, they should tell you what needs fixed before they can do a proper alignment and send you on your way. Most times they won't charge at that point because they know you'll be back for the alignment after you get the problem resolved.
  16. #16 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    May 2011
    Ontario
    Okay guys i officially don't know what to do. been doing some phoneing around. I have been telling shops my issue and they are all giving me different answers. Some shops are telling me they have no idea why one wheel would rub, so I ask if it could be wheel alignment issues and they say no.
    Some shops tell me that something could be wrong with the suspension which I don't wanna replace any more s**t on this car. Some shops say they won't touch it because its lowered. etc...car only has 70 000 miles on it. suspension feels fine no bouncing. These shops don't seem to know what they are talking about
    help! my tire is getting destroyed every day!
  17. #17 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    ROLL YOUR FENDERS!
    and get your alignment checked. you need an alignment after lowering a car. i guarantee your tow is all out of whack and you're gonna burn up your tires.
  18. #18 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    Get a blow dryer out there and heat up your fenderwell and take a baseball bat to the inside of it to roll your fender.
  19. #19 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    May 2011
    Ontario
    Got fed up with it and took a mallet and ower to it. I think it turned out well messed up the paint a bit on the inside but can't notice it. Hopefully this fixes the problem will see tomorrow on the drive to work.
    Also the reason I never got an alignment was because after lowering it rode the same tracked well and no un even tire wear. Been driving like that for 8 months no issues till now with switching wheels.
  20. #20 Re: Only one wheel rubbing with 20s 245/35/20 tires lowered on ssc?
    Lmao yup it should be a simple fix once you roll the fenders and get a alignment! Shouldn't matter if your lowered or not most shops can still align it.
    04 Comp G.
  1. New rear struts? Or tires too wide. Rubbing issues
    By Yarbeau in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2013, 01:10 PM
  2. Rubbing noise
    By cruzn in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2011, 09:56 PM
  3. patriots wheel and tires
    By gtpinsc in forum Off Topic Discussion
    Last Post: 01-07-2010, 10:08 PM
