Thread: Car wobbles side to side on initial take off.
Results 1 to 20 of 25
  1. #1 Car wobbles side to side on initial take off.
    Florida
    99 GTP.
    Recently my car started to have a wobble at take off and a vibration at high speeds. I got it up and front wheels off today and found the sway bar broken right on the drivers side clamp where it attaches to the frame at. Replaced it with the Dorman sway bar kit. Didn't make any difference. When braked and release and then accelerating, we're talking 5mph, the car feels like it's wobbling left and right. I pulled and pushed on the strut towers and all suspension parts but I didn't get any movement. Suggestions?
    Sent from my Galaxy Nexus using Tapatalk 2
  2. #2 Re: Car wobbles side to side on initial take off.
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Sounds like a bubbled tire or broken trans / motor mount
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  3. #3 Re: Car wobbles side to side on initial take off.
    Florida
    Quote Originally Posted by tms8582 View Post
    Motor mount and trans mount seem fine.
    Sent from my Barnes & Noble Nook HD+ using Tapatalk HD
  4. #4 Re: Car wobbles side to side on initial take off.
    Sep 2011
    Copperas Cove, TEXAS
    Seems like a separated tire. Check tires if one side of the tire is balding or less tread than the other half, then most likely a bad tire, had this problem a week ago. Replaced the tire and smooth as ice.
  5. #5 Re: Car wobbles side to side on initial take off.
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Needs a video so we can see what is going on.
    because then
    wobble baby, wobble baby, wobble baby, wobble.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  6. #6 Re: Car wobbles side to side on initial take off.
    I live here. DirtDog's Avatar
    Jun 2012
    When u say wobble at take off...u mean like a hard take off? Or a nice easy acceleration
  7. #7 Re: Car wobbles side to side on initial take off.
    Florida
    Quote Originally Posted by marines542 View Post
    Normal acceleration. If you put it in neutral and pushed it you'd feel it. Makes me think of wagon wheels wobbling.
  8. #8 Re: Car wobbles side to side on initial take off.
    SE Level Member Peirce1970's Avatar
    Myrtle beach, S.C.
    It could be a bad CV axle. My 04 did this when the left side was bad. It would wobble when I was accelerating and was smooth when I let off the gas.
  9. #9 Re: Car wobbles side to side on initial take off.
    Florida
    I do have some horizontal/left and right movement on the front tires when it's in the air. Not much but enough. I guess the inner tie rods are worn out and causing it to wobble when moving. Sound likely?
  10. #10 Re: Car wobbles side to side on initial take off.
    Myrtle beach, S.C.
    Did you check it at 12 and 6 to see if the hubs have play?
  11. #11 Re: Car wobbles side to side on initial take off.
    Jun 2012
    Quote Originally Posted by aeidian View Post
    That would be ur putter tie rods that are bad
    Quote Originally Posted by Peirce1970 View Post
    And do this...could be a hub.
    I wouldn't rule out CV half shafts. I've replaced both of mine.
  12. #12 Re: Car wobbles side to side on initial take off.
    Florida
    Hub didn't have any play, just the passenger tie rod. Gonna go get one and change it out then do the old tape measure alignment.
  13. #13 Re: Car wobbles side to side on initial take off.
    Florida
    Once I had the tire off the inner tie rod was not moving. When I moved the disc side to side I could see that it was moving without moving the tie rod, just a bit. Changed out the outer tie rod because the inner was solid, and the tire no longer moves at 3 and 9. However it didn't do **** towards fixing it. Coasting at 5 mph with no throttle the car shimmies and wobbles almost like a horse side to side. Shifting it to neutral changes nothing, it still wobbles. It's like that ****ed up cart at Walmart with the one bad wheel. It just wants to shift back and forth. I can't find anything loose no matter how much I pull or push. It's almost like it's a bent rim. Can these rims even bend since they're not steel? Would taking them to check the balance tell me if the rim is bent?
  14. #14 Re: Car wobbles side to side on initial take off.
    GT Level Member penright's Avatar
    Mar 2013
    United States
    I would think if you jack it up and set something next to the wheel for reference and spin it, then you see if it was moving. Also watch the gap between the ground and see if the tire is out of round.
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  15. #15 Re: Car wobbles side to side on initial take off.
    Rotate the front tires to the back, see if it stops. if they have low thread they could be egging on you, or getting a bubble/lump/hump in the tire.
    if it does it rolling in neutral id be all over a tire rotation, as nothing from the engine is powering the wheels.
    if the wheel is bent, a tire balance will show that.
  16. #16 Re: Car wobbles side to side on initial take off.
    Florida
    Good suggestions. The weekend is my work week, so it will have to be Monday before I check. Thanks for the replies.
  17. #17 Re: Car wobbles side to side on initial take off.
    Washington Michigan
    Yes like I mentioned before and others also it really sounds like a tire issue. I've had a bubble/hump on a tire cause exactly what you describe.
  18. #18 Re: Car wobbles side to side on initial take off.
    Mar 2013
    United States
    Also when you check the hub play at 6 and 12, do it with the tires on. I have replaced two and both of them had no play sitting on the bench. The tires add some leverage and that leverage is there going down the road. As have been previous mentioned, I am betting on a tire.
  19. #19 Re: Car wobbles side to side on initial take off.
    Florida
    Quote Originally Posted by penright View Post
    They were checked with the tires on, there's zero movement.
  20. #20 Re: Car wobbles side to side on initial take off.
    Florida
    Found the problem today, it was the driver's rear, had a large bubble on one part. I've never seen a tire do that, here's some pics
  1. AC blows Ice Cold on the Passengers Side and warm on the Drivers Side.
    By rynoman03 in forum General Tech Discussion
    Last Post: 08-08-2011, 11:18 PM
  2. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  3. Driver side wiper arm slips down to the side mirror
    By kappian in forum General Tech Discussion
    Last Post: 04-05-2010, 08:43 PM
  4. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
