Thread: Size bolt stud for FRONT control arm to subframe?
Results 1 to 9 of 9
  1. #1 Size bolt stud for FRONT control arm to subframe?
    Anyone know the actual head bolt diameter for the control arm that slides in between the subframe(rear), not to be mistaken with the torx type(front)? The holes on the subframe is elongated causing the passenger side wheel to wiggle in/out and messing up my alignment all over again when speeding and braking. To correct this, I was thinking about getting 2 grade 8 washers on the outside of the subframe holes and tak-weld it to the subframe(basically new holes) to prevent the head bolt/control arm from wiggling.
    TIA
  2. #2 Re: Size bolt stud for FRONT control arm to subframe?
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Damn, haven't seen that before...
    So they are egg shaped from it being loose and violently smashing around in there I guess?
    I would do a little more than tac weld but I don't see why that wouldn't last at least a little while provided the washer were thick enough. If you have the ability to weld though, you probably have the ability to cut and drill some thicker bigger pieces of metal which would hold up longer. Or maybe even weld the nut itself to one side and repair the other side with a washer/fab your own. As for your question why not just take it out real quick and caliper it? Instead of relying on interwebs peoples who will probably just guess and say 1/2"
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  3. #3 Re: Size bolt stud for FRONT control arm to subframe?
    Get a new subframe, our local pick n pull charges about $50 for subframes.
  4. #4 Re: Size bolt stud for FRONT control arm to subframe?
    i was under the impression swapping subframe's a difficult task and this is my DD unfortunately. i could take out the bolt but then i'm concerned the alignment would be even more messed up. i was hoping if someone has the exact measurements and let me know theh i could get the proper thickness and hole size for the stud, remove it and weld the washers on the subframe then go for a re-alignment afterwards to save on tire treadware. thats my thought process anyhow lol
  5. #5 Re: Size bolt stud for FRONT control arm to subframe?
    Swapping subframes is easy, support the engine and trans from above, a lot of people just use a 4x4 across the inside or the fenders and a chain, jack up and support vehicle, remove both front tires, remove the 2 engine mount bolts 15mm iirc remove the 2 tranny mount bolts i think they are the same as the engine mounts, unclip the wiring harness for the abs sensors unhook the power steering lines if your car has it unlpug the magnasteer connector from the steering rack remove the lower control arms if you are keeping them use a 2x4 and a floor jack to support the subframe, remove the 4 subframe bolts 18mm, and out she comes. If you want to keep your steering rack you will need to swap that over obviously. If you don't run into any issues it should only take about 2-3 hours to do the swap.
  6. #6 Re: Size bolt stud for FRONT control arm to subframe?
    St. Louis
    I have a brand new set of Moog LCA's in my garage at home. I could measure the bolt holes on one of them if this is what you're looking for. I don't have the actual bolt though as it's still on the car/old arms.
  7. #7 Re: Size bolt stud for FRONT control arm to subframe?
    Feb 2010
    Oklahoma City, OK
    Swapping a subframe isn't hard but there's plenty of opportunity for things to go wrong if your not familiar with that type of work or even if you are. Should be able to jack it up take wheel off and weld some plates, washer, nuts or whatever on in like a half hour and have no problems from it again. Or even welding the nut alone in place should keep it from shifting and you wouldn't even have to take it loose or take the wheel off if your good, just don't weld too hot for too long or that bushing will probably catch fire lol
  8. #8 Re: Size bolt stud for FRONT control arm to subframe?
    I would take the lower control arm off I was to go about welding it on, I think some plates would work better in the long run than washers or welding the nut on.
  9. #9 Re: Size bolt stud for FRONT control arm to subframe?
    Feb 2010
    Oklahoma City, OK
    I just so happen to have a car(my old car from my sig) here at the house tore down that I was swapping flexplates on and have the bolts out. If you still need measurements or pictures let me know, I'll have it tore down for a while to say the least after what I found when I pulled trans. So let me know or PM me if you still need it...
  1. Squeaking coming from front subframe area
    By 1filthygp in forum Brakes/Suspension/Chassis
    Last Post: 05-26-2013, 08:51 AM
  2. Lower control arms or subframe bushings? (do these look bad to you?)
    By andante147 in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2013, 10:04 PM
  3. Transmission pan bolt size?
    By quickster in forum General Tech Discussion
    Last Post: 08-05-2012, 01:25 AM
  4. 93 grand prix front subframe bushings
    By Mike Preston in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2012, 02:38 PM
  5. Bolt Size
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2009, 06:40 AM
