Thread: Rattling noise when hitting bumps?
Results 1 to 9 of 9
  1. #1 Rattling noise when hitting bumps?
    Apr 2013
    Michigan
    Ive noticed a rattling type noise in the rear driver side corner in my gp, its a coupe if it makes any difference lol. It almost sounds like the seatbelt hitting or something rattling inside the wall, any other ideas of what it could be or how to solve the issue?
  2. #2 Re: Rattling noise when hitting bumps?
    Jan 2012
    FT Campbell, KY
    I'd challenge you to check the brake caliper floating pins/bolts first for security. I had worked one loose somewhere along the way and it fell out. The sound you're describing was reminiscent of my caliper flapping around a little bit.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  3. #3 Re: Rattling noise when hitting bumps?
    Apr 2013
    Michigan
    alright thanks, could it possibly be a ball joint?
  4. #4 Re: Rattling noise when hitting bumps?
    There is no ball joint in the rear of your car.
  5. #5 Re: Rattling noise when hitting bumps?
    Sway link?
  6. #6 Re: Rattling noise when hitting bumps?
    Sep 2011
    Copperas Cove, TEXAS
    It's normal GP noise, just turn up the radio and worry once something falls off.
    Something simple most likely, just have to jack it up and recheck tightness of things.
  7. #7 Re: Rattling noise when hitting bumps?
    St. Louis
    Could be a rear strut mount as well. I know mine clunk sometimes if I hit a bump/pothole just right. As tanker said its time to throw it on a jack and jackstands and take a look for anything loose, or that shows signs of movement where there shouldn't be (shiny metal on a painted/coated surface, etc..).
  8. #8 Re: Rattling noise when hitting bumps?
    Nov 2011
    NY
    Could be any of the aforementioned items or something totally unexpected.
    You've got to get under there and take a look see. Get you hands on things and see what's loose.
    Not mentioned but I'd check you exhaust system hangers as well... : )
  9. #9 Re: Rattling noise when hitting bumps?
    Apr 2013
    Michigan
    alright
  1. Wired noise when going over bumps... Help!
    By apierce1289 in forum General Tech Discussion
    Last Post: 04-01-2013, 04:07 PM
  2. I'm pretty sure hitting big bumps is opening my trunk..
    By GTLGDP in forum General Tech Discussion
    Last Post: 01-22-2012, 08:09 PM
  3. Hitting bumps really hard
    Last Post: 11-17-2011, 01:46 PM
  4. Rattling going over bumps. And while braking. SOLVED
    By speedy2 in forum Brakes/Suspension/Chassis
    Last Post: 04-28-2011, 04:16 PM
  5. Rattling felt (and heard) in steering when turning and going over bumps
    By michgym170 in forum Brakes/Suspension/Chassis
    Last Post: 10-07-2009, 10:41 AM
