Thread: Inside driver front brake pad worn to nothing 8K miles
Results 1 to 2 of 2
  1. #1 Inside driver front brake pad worn to nothing 8K miles
    Cambridge, Ontario Canada
    I am thinking sliders?
    2005 E55 - stock
  2. #2 Re: Inside driver front brake pad worn to nothing 8K miles
    its either un greased, or rusted sliders, or the caliper needs to be re built.
    inside is almost always a bad caliper. means its dragging, aka not being let loose after you let the brakes go. car should pull to that side as well if the pads are dragging.
  1. Front driver side wheel pissing brake fluid :(
    By apierce1289 in forum Brakes/Suspension/Chassis
    Last Post: 05-08-2013, 06:35 AM
  2. which worn parts to replace at almost 90k miles?
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 11:30 AM
